  • 1.  receiving report exception
    Posted 08-11-2024 04:42
    run report of receiving
    nasr buzaid
    eni
  • 2.  RE: receiving report exception
    Posted 08-13-2024 04:01
    Hi Nasr,
    Seems like you are trying to run a report. I would suggest to do the following:
    1) the parameters that you are giving while running the report, give the same parameters in your db and check if you are getting any result or not.
    2) try running in a different browser too.
    Trisha
  • 3.  RE: receiving report exception
    Posted 08-14-2024 20:09
    Hi Nasr,
    I would also suggest turning on DEBUG logging for the 'report' logger in Logging app. Certainly for a test system (or if working in Production, just briefly). It will give you a lot of details about the report and the parameters passed to it. There should also be an error in the log relating to this anyway?
    Cheers,
    Steve
    Steve Bruce
