Hi Viet, i'm trying to go to the url you posted. I resulted in :
This site can't provide a secure connection
blog.relia.app sent an invalid response.
IS there another way to read your advice?
Thanks in advance.
Kin dregards,
Hessel
Hessel Ebbes
VMI GROUP
Sent: 12-15-2023 14:00
Subject: Reload error and error 500 internal error
Check the Load Balancer's session timeout, and Websphere LTPA token timeout. They are different to Maximo's session timeout but also have the same power of kicking you out mid-session. I have some notes about it in this post: https://blog.relia.app/2022/06/common-issues-when-setting-up-maximo-with-a-load-balancer/
Viet Tran
Relia
Sent: 12-14-2023 10:31
We also are seeing this after going to 7.6.1.3 and SSO . We have set up 2 aliases for logons. Example might be: maximoproduction/maximo or maximoproduction.abc.int/maximo. We have found that the fully qualified url - maximoproduction.abc.int/maximo works more efficiently with far fewer of these pop ups and runs the KPI's off the start centers more efficiently. Still seeking root cause.
Daniel Beyler
Allison Transmission
