  • 1.  Reorder crontask
    Posted 11-06-2023 13:02
    Reorder crontask generate empty PR. I have checked the reorder crontask logs but the generated PR lines and logs reorder is mismatch. How come reorder generate empty PR lines.
    Thanks in advance.
    Abirami Sivakumar
    Capgemini
  • 2.  RE: Reorder crontask
    Posted 11-07-2023 10:23
    the answers should be in the the reorder cron logs and the JVM logs.
    There are multiple reasons why the PRs are not being generated e.g. missing values / invalid values.
    mark robbins
    Cohesive
  • 3.  RE: Reorder crontask
    Posted 11-08-2023 15:37
    I would recommend running reorder in the background, so it sends an email.  That usually has a lot more information.
    Shannon Rotz
    InComm Solutions Inc.
  • 4.  RE: Reorder crontask
    Posted 11-08-2023 23:03
    Try double-checking the preview reorder action on inventory, confirming that it's valid for reorder. Also, check if the vendor is valid.
    You can also verify if there are no global restrictions or automation scripts that could stop the cron from adding the items to the PR line. Can you create the PR for the vendor and select the item that should be considered in the reorder process?
    Cheers.
    Maycon Belfort
    BPD Zenith
  • 5.  RE: Reorder crontask
    Posted 11-10-2023 11:49
    First you can do a preview reorder to check if that falls in the reorder process or not. One thing I had noticed earlier that if there is no order unit for that particular item,pr generation fails. You can check that too and lastly logs would give a better way to troubleshoot.
    Deepa P
