  • 1.  Scheduled report error
    Posted 19 hours ago
    I have one report that runs fine but recently it doesn't when scheduled. It is a custom report that has been used for years. It fails when choosing XLSX, but it is fine as XLS.
    The report is designed to only have one page using XLSX. I have many reports that use the same logic for XLSX that work fine.
    Has anyone run into this?
    The error is as follows.
    17 Aug 2026 08:30:33:735 [INFO] [MXServer] [CID-CRON-101063] Correlation started.
    17 Aug 2026 08:30:33:762 [INFO] [MXServer] [CID-CRON-101063] Correlated data: BEGIN InstanceName:AsyncImmediate TaskName:AsyncImmediateJobCron ElapsedTime:27 ms  END
    17 Aug 2026 08:30:34:397 [DEBUG] [MXServer] [] Report Run Thread [maximo-ReportRunThread-4] wokeup for work.
    17 Aug 2026 08:30:34:397 [DEBUG] [MXServer] [] Report Run Thread [maximo-ReportRunThread-4] noticed Queue is Empty.
    17 Aug 2026 08:30:34:397 [DEBUG] [MXServer] [] Report Run Thread [maximo-ReportRunThread-4] waiting for work.
    17 Aug 2026 08:30:35:799 [INFO] [MXServer] [] DataSet [dataSet] close called.
    17 Aug 2026 08:30:36:021 [ERROR] [MXServer] [] Failed to run queued report.
    psdi.util.MXApplicationException: BMXAA5480E - The report OpenmaterialPOsagingETO2.rptdesign of the PO application failed to run.
                    Error happened while running the report.
                    at com.ibm.tivoli.maximo.report.birt.admin.ReportAdminService.runReport(ReportAdminService.java:3643)
                    at com.ibm.tivoli.maximo.report.birt.admin.ReportAdminService.runReport(ReportAdminService.java:3561)
                    at com.ibm.tivoli.maximo.report.birt.queue.ReportQueueManager.runQueuedReport(ReportQueueManager.java:933)
                    at com.ibm.tivoli.maximo.report.birt.queue.ReportQueueManager.runQueuedReport(ReportQueueManager.java:857)
                    at com.ibm.tivoli.maximo.report.birt.queue.ReportQueueManager.doWork(ReportQueueManager.java:659)
                    at com.ibm.tivoli.maximo.report.birt.queue.ReportQueueManager$ReportRunThread.attemptToRunReport(ReportQueueManager.java:514)
                    at com.ibm.tivoli.maximo.report.birt.queue.ReportQueueManager$ReportRunThread.run(ReportQueueManager.java:453)
    Caused by:
    com.ibm.tivoli.maximo.report.birt.runtime.ReportExecutionException: Error happened while running the report.
                    at com.ibm.tivoli.maximo.report.birt.engine.MXReportEngine.executeReport(MXReportEngine.java:447)
                    at com.ibm.tivoli.maximo.report.birt.engine.MXReportEngine.executeReport(MXReportEngine.java:147)
                    at com.ibm.tivoli.maximo.report.birt.admin.ReportAdminService.runReport(ReportAdminService.java:3608)
                    ... 6 more
    Caused by:
                    at com.ibm.tivoli.maximo.report.birt.runtimeprovider.XLSReportGenerator.generateReport(XLSReportGenerator.java:117)
                    at com.ibm.tivoli.maximo.report.birt.runtimeprovider.ReportExecutionTaskImpl.executeReport(ReportExecutionTaskImpl.java:133)
                    at com.ibm.tivoli.maximo.report.birt.engine.MXReportEngine.executeReport(MXReportEngine.java:424)
                    ... 8 more
    Caused by:
    org.eclipse.birt.report.engine.api.EngineException: Error happened while running the report.
                    at org.eclipse.birt.report.engine.api.impl.EngineTask.handleFatalExceptions(EngineTask.java:2363)
                    at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doRun(RunAndRenderTask.java:191)
                    at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run(RunAndRenderTask.java:77)
                    at com.ibm.tivoli.maximo.report.birt.runtimeprovider.XLSReportGenerator.generateReport(XLSReportGenerator.java:111)
                    ... 10 more
    Caused by:
    java.lang.NullPointerException
                    at uk.co.spudsoft.birt.emitters.excel.ExcelEmitter.end(ExcelEmitter.java:273)
                    at org.eclipse.birt.report.engine.emitter.CompositeContentEmitter.end(CompositeContentEmitter.java:65)
                    at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doRun(RunAndRenderTask.java:183)
                    ... 12 more
     Thx
    WES WILLIAMS  |  Sr. Principal Software Development Analyst
    Northrop Grumman |  Enterprise Services
    O: 405-736-8253  |  wes.williams@ngc.com
    Wes Williams
    Northrop Grumman
