Maximo User Groups / Conferences
Show error when the project budget exceeds
  • 1.  Show error when the project budget exceeds
    Posted 11-02-2024 10:29
    I have created a script to throw error when the budget is exceeded from the work order application with the below script using object lp WORKORDER.
    def setError(messageKey, messageGroup,arguments):
        global errorkey,errorgroup, params
        errorkey = messageKey
        errorgroup = messageGroup
        params = arguments
    if (mbo.isModified("ABVBUDGETREMAINING_NP") or mbo.isModified("ACTTOTALCOST") or mbo.isModified("ACTLABCOST")):
        budgetAmount=mbo.getDouble("ABBCURRCOMMIT")
        balBudgetAmount=mbo.getDouble("ABVBUDGETREMAINING_NP")
        if (balBudgetAmount<0):
             setError("ABVBUDGETEXCEED","ABVBUDGET",[mbo.getString("ABBENGR"),budgetAmount])
    Now my requirement is to show the same error that the project budget is exceeded when i am reporting from the Labor reporting application by choosing Enter by work order.
    I am choosing Labor reporting module, then from the  common actions i am picking Enter by work order and giving the work order details and creating a new row to chose the Labor. After filling the costs /rate, i am clicking ok and the record is getting saved which is not correct.
    Note: The budget remaining is in negative number, also the actual total cost is greater than the budget amount in the work order module.
    So could anyone please help to write an automation script to show the same error that the project budget is exceeded when i am reporting from the Labor reporting application by choosing Enter by work order.
    Thanks in Advance
    Ishwarya Soundarya
    Accenture
