  • 1.  SQL Query in Automation Script
    Posted 01-31-2023 10:54
    I have an existing sql query that I want to convert into scripting which will be programmed using Automation Script in Maximo, however, I'm not familiar on how it will work, can someone help me with my autoscript?  Thank you!
    Here is the sql query:
    select  transdate, laborcode, regularhrs,premiumpayhours, premiumpayrate, enterby, timereportid from labtrans where ext_paysent = 0 and trunc(sysdate) =  (select DueDate from EXT_TIMEREPORTPAYPERIOD where active=1)
    and to_date(transdate) between (select PAYDATEBEGIN from EXT_TIMEREPORTPAYPERIOD where active =1)
    and (select PAYDATEEND from EXT_TIMEREPORTPAYPERIOD where active = 1) and timereportid is not null
    and regularhrs =0 and PREMIUMPAYHOURS is null;
    Here is the autoscript:
    from psdi.server import MXServer;
    from java.sql import Statement;
    from java.sql import PreparedStatement;
    from java.sql import Connection;
    from java.sql import ResultSet;
    from psdi.mbo import Mbo;
    import time;
    mxserver = MXServer.getMXServer();
    userInfo = mxserver.getSystemUserInfo();
    # Get a Database COnnection from a Maximo Server
    currentSet = mxserver.getMboSet("LABTRANS",userInfo);
    currentMbo = currentSet.getMbo(0);
    con = currentMbo.getMboServer().getDBConnection(userInfo.getConnectionKey());
    # Get a schema name of the server to know from which instance it is running
    schema = currentMbo.getMboServer().getSchemaOwner();
    schema = schema.upper();
    str = ['Maximo 7.6.1.2 Database ',schema,' is working!','\n','\n'];
    # ' is not acceptable as part of String. it is included in Backlash \ in List and converted to String
    labtransQuery = ['select laborcode, regularhrs, premiumpayhours, premiumpayrate, enterby, timereportid from labtrans where changeby = ','\'','MXINTADM','\'','group by timereportid'];
    labtransQuery = ''.join(labtransQuery);
    outboundQuery = ['select duedate, paydatebegin, paydateend from ext_timereportpayperiod where active = 1 and group by timereportid']
    outboundQuery = ''.join(outboundQuery);
    try:
    s= con.createStatement();
    rs1 = s.executeQuery(labtransQuery);
    str.append('--------------------------------------');
    str.append('\n');
    str.append(' Labor Code');
    str.append('\n');
    str.append('\n');
    while(rs1.next()):
    laborcode= rs1.getString('timereportid');
    # Converts a time to a String of readable format
    #changetimeString = time.strftime("%d-%b-%Y %I:%M:%S",changetime)
    # Conversion of date to string depends on Database DATE format
    str.append(companyset);
    str.append('\t');
    #str.append(changetimeString);
    str.append(date);
    str.append('\n');
    rs1.close();
    str.append('\n');
    rs2 = s.executeQuery(outboundQuery);
    str.append('\n');
    str.append('DUEDATE| PAYDATEBEGIN| PAYDATEEND');
    str.append('\n');
    str.append('\n');
    if (rs2.next()== False):
    str.append('--NO RECORDS--');
    str.append('\n');
    else:
    while True:
    orgid = rs2.getString('duedate');
    siteid = rs2.getString('paydatebegin');
    count = rs2.getString('paydateend');
    str.append(duedate);
    str.append('\t');
    str.append(paydatebegin);
    str.append('\t');
    str.append(paydateend);
    str.append('\n');
    if (rs3.next() == False) :
    break
    rs2.close();
    str.append('\n');
    s.close();
    except Exception, e:
    str.append("error in db");
    Eugenio Cabalhin
    IBM Solutions Delivery Inc
  • 2.  RE: SQL Query in Automation Script
    Posted 01-31-2023 11:55
    Moreover, is there any way to automate this script apart from a scheduled escalation or cron task? Thank you!
    Eugenio Cabalhin
  • 3.  RE: SQL Query in Automation Script
    Posted 02-01-2023 10:46
    You are doing way too much work! Let Maximo take some of the load off!
    You have these two lines too close together:
    currentMbo = currentSet.getMbo(0);​
    Adding a line between these two, as shown below, should achieve the end you first laid out, of getting data from `labtrans` based on a where clause.
    currentSet.setWhere(
        "ext_paysent = 0 "
        "and trunc(sysdate) = (select DueDate from EXT_TIMEREPORTPAYPERIOD where active=1) "
        "and to_date(transdate) between (select PAYDATEBEGIN from EXT_TIMEREPORTPAYPERIOD where active =1) "
        "and (select PAYDATEEND from EXT_TIMEREPORTPAYPERIOD where active = 1) "
        "and timereportid is not null "
        "and regularhrs =0 "
        "and PREMIUMPAYHOURS is null"
    currentMbo = currentSet.getMbo(0);​​
    You can then do a `currentMbo.getDate("TRANSDATE")`, for example, to get back one of the columns you said you wanted from `labtrans`.
    I hope that helps.
    Jason Uppenborn
    Cohesive
  • 4.  RE: SQL Query in Automation Script
    Posted 02-22-2023 06:53
    Thank you so much for your help!
    Eugenio Cabalhin
