  • 1.  SQL to capture workorders holding only 1 assignment.
    Posted 03-14-2025 04:16
    Hi, is it possible to write an SQL statement in the Where Clause function, that returns only work orders holding only 1 assignment, not multiple?
    Thankyou
    Rob
    #WorkCenters
    Rob Heeney
    Mitie
  • 2.  RE: SQL to capture workorders holding only 1 assignment.
    Posted 03-14-2025 10:14
    Assuming you want only where the assignment is tied to the main work order (not at a task level) you can do something like below:
    historyflag=0 and istask=0 and 1=(select count(1) from assignment where assignment.wonum=workorder.wonum and assignment.siteid=workorder.siteid)
  • 3.  RE: SQL to capture workorders holding only 1 assignment.
    Posted 03-21-2025 09:36
    Thanks Steven,
    Is there a way to construct this further? If we wanted to see only workorders with 1 assignment, and that assignment held a specific craft?
    Rob
    Rob Heeney
    Mitie
  • 4.  RE: SQL to capture workorders holding only 1 assignment.
    Posted 03-21-2025 13:32
    Since you want 1 assignment on the record and that 1 assignment must be for a specific craft, you'd need to do it like this:
    historyflag=0 and istask=0 and 1=(select count(1) from assignment where assignment.wonum=workorder.wonum and assignment.siteid=workorder.siteid) and exists(select 1 from assignment where assignment.wonum=workorder.wonum and assignment.siteid=workorder.siteid and assignment.craft='YOURCRAFT')
    Replacing 'YOURCRAFT' with the actual craft such as 'MECH'
