  • 1.  Start Center Result Set
    Posted 09-25-2024 07:43
    Is there a way to get related tables in a start center result set? In particular, for an Inventory result set, only the "Inventory Details" are available, no other tables (for inventory balances and item descriptions). The object structures have the correct relationships, but they don't show when designing the result set.
    Jason Johnson
    RSI
  • 2.  RE: Start Center Result Set
    Posted 09-26-2024 10:54
    The "object structure" listed below the application can be opened in the Object Structures app. Make a copy and add the related MBOs, and they should appear in the Object List in a tree.
    Robert Goff
    Xanterra Travel Collection
  • 3.  RE: Start Center Result Set
    Posted 09-26-2024 11:00
    I thought that might be the case, but our object structure already has the relationships we're looking for.
    Jason Johnson
    RSI
  • 4.  RE: Start Center Result Set
    Posted 09-26-2024 12:26
    Jason,
    In Report Administration, does the User's Security Group have access to the "Inventory Details" Report Object Structure?  You might want to check there as well.
    Steve Platt
    Maximo Administrator
    Georgia Building Authority
  • 5.  RE: Start Center Result Set
    Posted 09-26-2024 12:34
    Same as your screenshot. I'm designing the result set as a member of MAXADMIN.
    Jason Johnson
    RSI
  • 6.  RE: Start Center Result Set
    Posted 09-26-2024 14:51
    The 1:many tables like INVBALANCES are not supported in result sets. You can get them to display by enabling the webclient.allowMultipleCardinality system property, but it will only ever display 1 row for the main object. More specifically, you could have 10 bins for a part in inventory. You will see data from only 1 bin.
    Item is 1:1 but I assume the correct cardinality wasn't set when you added that object to the object structure. In the object structures application, make sure you define it as SINGLE cardinality. Multiple, undefined, or null will be treated as one to many relationships
  • 7.  RE: Start Center Result Set
    Posted 10-06-2025 20:06
    Hello @Steven Shull, I am wanting to test adding PR to this application choice.  Do I need to do the above for that?
  • 8.  RE: Start Center Result Set
    Posted 10-06-2025 20:17
    You would see PR as a valid application whether or not you had object structures configured in the application. If you did not have access to a report object structure for PR, then you would only be able to select details from the main PR object (wouldn't be allowed to select things like the PRLINE).
    If you don't see the PR application, make sure you have security access to the PR application and a saved query that you can see. That means either a saved query that is public or a saved query that you made if it's private. Since a query is required (we don't want to fetch entire tables), IBM makes sure that you can pick a query before letting you select the application.
