  • 1.  The SENDERSYSID is not being populated on inbound messages.
    Posted 10-24-2024 15:03
    Hello everyone,
    I'm working on an integration project and have an object structure that points to the FINCNTRL table. There's also a JSON mapping for it. The purpose of this integration is to add new records. After testing, I noticed that the SENDERSYSID is not being populated, while all other fields are successfully populated. Is there any known reason why this field is being ignored?
    Thanks.
    Victor G
    acw
  • 2.  RE: The SENDERSYSID is not being populated on inbound messages.
    Posted 10-29-2024 07:37
    Did you check if SENDERSYSID  is included in the Object Structure (Exclude / Include fields)?
    Prajesh Pradhananga
    SRP
  • 3.  RE: The SENDERSYSID is not being populated on inbound messages.
    Posted 10-29-2024 13:03
    Yes, I checked that the field is included and also enabled the override flag but nothing works, do you have anything else in mind?
    Victor G
    acw
  • 4.  RE: The SENDERSYSID is not being populated on inbound messages.
    Posted 10-31-2024 06:58
    What is the value for : select * from maxvars where varname like '%MXSYSID%'
    This field is usually for Outbound. For inbound it would be preferable to set value on the Inbound processing rule.
    Niv Geo
  • 5.  RE: The SENDERSYSID is not being populated on inbound messages.
    Posted 01-17-2025 09:59
    Did you find a solution to this question? I am switching from a SOAP API to REST and I haven't figured out how to set SENDSYSID.
    Rob
    Rob White
    Charlotte Pipe and Foundry Company
  • 6.  RE: The SENDERSYSID is not being populated on inbound messages.
    Posted 01-18-2025 01:48
    if OS support flat file, check Alias conflict
    Abdelrahman Abbas
    RATPdev
