  • 1.  #TipTuesday – Action Buttons have been Moved
    Posted 03-03-2026 13:00
    Edited by Erin Pierce 03-03-2026 14:41
    As with many things in Maximo, action buttons have been moved in MAS. As an example, within Manage, to add a ‘New Row’, there is now a + button above the table you are adding to by default. In 7.6, there was a button below the table that said, ‘New Row’. As with many other UI features I have covered in previous #TipTuesdays, there is a system property that you can use to control this.
    Review the property mxe.webclient.tableButtonPlacement within your system. There are a few different options you can select from. Today in MAS, the default is 1. If you read the system property description, you can find out which values are available for displaying table buttons. Your options are 0=Display at bottom. 1=Display at top. 2=Display both.
    In this screenshot, I have the setting set at 2 to show you both options:
    A screen shot of a computer
AI-generated content may be incorrect.
    Happy #TipTuesday! I hope this improves your experience with new rows in Manage.
    #TipTuesday
    Allan Henle
  • 2.  RE: #TipTuesday – Action Buttons have been Moved
    Posted 03-05-2026 09:01
    This is good to know! Are the next page action buttons (from list views) able to be moved from the bottom to the top in a similar way? Snip below.
    Kristina Strozzo
    Great Dane
  • 3.  RE: #TipTuesday – Action Buttons have been Moved
    Posted 03-05-2026 11:09
    Hi Kristina,
    Unfortunately, there is no system property to move the 'next page' action from a table.
    Allan Henle
  • 4.  RE: #TipTuesday – Action Buttons have been Moved
    Posted 03-06-2026 08:56
    This is possible in MAS 9.1. A new system property (mxe.webclient.paginationButtonsPlacement) was added that can let you move to the top or both if you prefer (with the default staying the bottom like earlier versions of MAS)
  • 5.  RE: #TipTuesday – Action Buttons have been Moved
    Posted 03-09-2026 15:15
    Thanks, Allan and Steven. That's good to know on both counts!
    Kristina Strozzo
    Great Dane
