  • 1.  To create Change Status Action for custom application
    Posted 07-27-2023 06:21
    Edited by Christopher Winston 07-27-2023 09:30
    Needed some guidance on implementing simple change status action,  for the custom application which is created using custom object.
    I am new to this  java customization and tried following below procedure got stuck.
    • created 3 objects: 1st one main object, 2nd persistence object and 3rd one non-persistence object.
    • Created Synonym domain from backend and attached in the status fields of all the 3 objects .
    • In the main object  class path: Created class file which extends statefulmbo and provided set class path which extends mboset  , not override any methods
    • In the 2nd persistence object : Created a class file which extends mbo and provided set class path which extends mboset
    • In the 3rd non-persistence object: created a class file which extends changestatus and provided set class path which extends ChangeStatusSet
    • created one dialog box and used common bean class and displayed all the fields of 3rd non-persistence  object using relationship
    By following all these still status is not getting changed.
    Please advice on the same.
    Roja
    #MaximoForAviation
    Roja P
  • 2.  RE: To create Change Status Action for custom application
    Posted 07-28-2023 01:05
    Hi Roja,
    What error you are getting while trying to change the Status in the dialog box?
    Subhransu
    Subhransu Sekhar Sahoo
    PriceWaterHouseCoopers Services Pvt Ltd
  • 3.  RE: To create Change Status Action for custom application
    Posted 07-28-2023 11:34
    Edited by Roja P 07-28-2023 12:26
    Hi Subhransu,
    I'm actually not getting any error while am trying to perform change status action. However the values are not getting saved in my main object -status field but the dailog box is working fine.
    Roja
    Roja P
  • 4.  RE: To create Change Status Action for custom application
    Posted 10-27-2023 08:55
    I would recommend you to check the status handler class and custom mbo  class and the following methods in it
    public void changeStatus(String currentStatus, String desiredStatus, Date date, String memo)--- In handler
    public void changeStatus(String status, Date date, String memo)---In your custom mbo  class
    Nidhil Chathoth
    ECCS Ltd
Featured Podcast
Watch the Podcast
Watch the latest episode
