Maximo Solutions
Tracking Rogue Spend & Maverick Buying for Maximo | 15 Min Webinar Series
  • 1.  Tracking Rogue Spend & Maverick Buying for Maximo | 15 Min Webinar Series
    Posted 06-10-2026 10:51
      |   view attached
    If you don't know exactly what your team is buying through rogue spend and maverick buys, how are you supposed to address the problem? Most organizations only see an amount and a supplier name on a credit card statement or a "description-only" PO.
    Without knowing which specific parts were purchased, which assets they were for, or why the standard process failed, you are left with "blind spots" in both upstream and downstream MRO supply chain processes.
    Upstream, you lose visibility into where your procurement process is breaking down.
    Downstream, buyers, receiving, inventory, AP, and leadership lose the data they need for spend analytics, inventory planning, vendor negotiations, and future sourcing decisions.
    At P2Insight, we believe the first step to optimization is visibility. We help you gather granular data at the point of purchase so you can finally analyze your spend and deal with the root causes of procurement leakage.
    Watch our 15-minute webinar to learn how to:
    Eliminate Spend "Blind Spots"
    Understand why simply having a supplier name and a total isn't enough to drive real savings.
    Finally Capture the "What, Where, and Why":
    See our optimized Spot Buy process that captures full item details, Work Order links, and the specific "reason for failure" directly in Maximo.
    Turn Receipts into Strategy: Learn how to use a complete audit trail to identify "Ghost Inventory" and improve your next round of contract negotiations. Stop guessing where your MRO budget is going.
    Click here to watch the full webinar: https://youtu.be/ctUAojMcb34
    Stevan Japundzic
    P2Insight
