  • 1.  Unable to change Work Order status to "Close" due to the following error - BMXAA0031E - The INVRESERVE object is read only. Verify the business rules for the MBO or MBOSET object.
    Posted 11-04-2022 05:23
    Ben Lephuthing
    Rand Water
  • 2.  RE: Unable to change Work Order status to "Close" due to the following error - BMXAA0031E - The INVRESERVE object is read only. Verify the business rules for the MBO or MBOSET object.
    Posted 12-16-2022 13:20
    Even I am getting above error while closing the WO. Can some one help us please.
    Balaji Reddy
    infosys
  • 3.  RE: Unable to change Work Order status to "Close" due to the following error - BMXAA0031E - The INVRESERVE object is read only. Verify the business rules for the MBO or MBOSET object.
    Posted 12-19-2022 09:39
    Hi y'all,
    Is it all work orders or just this work order? Have you narrowed down any criteria (site, users, data on the WO)? I would image it's work orders with planned materials? Have you checked Object Restrictions in the Global Data Restrictions?
    Matt McGuire
    Aquitas Solutions
  • 4.  RE: Unable to change Work Order status to "Close" due to the following error - BMXAA0031E - The INVRESERVE object is read only. Verify the business rules for the MBO or MBOSET object.
    Posted 04-07-2025 11:37
    Hi Ben,
    We are getting similar error "BMXAA0031E - The WPMATERIAL object is read only. Verify the business rules for the MBO or MBOSET object.", when trying to change the WO to close, there is nothing much in the logs.
    Please share if you found the fix for your issue?
    Thanks.
    Neel Sam
    IT
  • 5.  RE: Unable to change Work Order status to "Close" due to the following error - BMXAA0031E - The INVRESERVE object is read only. Verify the business rules for the MBO or MBOSET object.
    Posted 04-07-2025 11:38
    Hi Ben,
    We are getting similar error "BMXAA0031E - The WPMATERIAL object is read only. Verify the business rules for the MBO or MBOSET object? when trying to change the WO to close." when trying to close WO, there is nothing much from logs.
    Could you please share steps taken to resolve your issue with INVRESERVE ?
    Thanks.
    Neel Sam
    IT
