  • 1.  Unable to install MAS in AWS ROSA due to permission issue
    Posted 04-06-2026 05:44
      |   view attached
    I am trying to install IBM Maximo Application Suite (MAS) on AWS ROSA.
    To provide an RWX storage class during MAS installation, we created an AWS EFS filesystem and defined a new StorageClass using the EFS CSI driver.
    However, during the installation pipeline, the db2-manage step is failing with the following errors.
    db2-manage log
    Checking Deployments are healthy (40/40 retries with a 300 second delay)
    [NOTREADY] db2u/c-mas-xxxx-manage-ldap = 1 replicas/None ready/1 updated/None available
    Finished check: Delaying 300 seconds before next check
    LDAP Pod Log
    + sleep 5
    + [[ ! -f /mnt/blumeta0/home/db2inst1/.initdb ]]
    + sleep 5
    INSTDB Pod Log
    utils.command_runner.command.CommandException: Command failed to run:
    sudo: unable to send audit message: Operation not permitted
    chown: changing ownership of '/mnt/blumeta0/db2': Operation not permitted
    The DB2 INSTDB pod is in an error state with the above messages. Attached the EFS Storage class that we created in OpenShift.
    Has anyone faced similar issues with DB2 on EFS in ROSA? Any insights on resolving the error?
    Kumaresan Kumar
    Attachment(s)
    txt
    EFS Storage Class.txt   356 B 1 version
  • 2.  RE: Unable to install MAS in AWS ROSA due to permission issue
    Posted 04-07-2026 07:34
    Hello Kumaresan,
    May I know how you have created the efs setup. Could you try with ocp_efs ansible role.
    Also, Could you double check whether all the pre requisites have been completed from the both MAS and database perspective.
    https://www.ibm.com/docs/en/masv-and-l/cd?topic=services-prerequisites-installing
    https://www.ibm.com/docs/en/masv-and-l/cd?topic=services-configuring-installation-permissions
    https://www.ibm.com/docs/en/masv-and-l/cd?topic=services-preparing-install
    https://www.ibm.com/docs/en/masv-and-l/cd?topic=services-security-considerations
    Tinnokesh AP
