  • 1.  Update Owning Department (creating location)
    Posted 07-02-2024 15:45
    I'm attempting to add a new location in Maximo, but I can't figure out how to add an owning department. Pictures attached for reference.
    Thanks in advance,
    Zach
    Zachery Cooley
    Danfoss
  • 2.  RE: Update Owning Department (creating location)
    Posted 07-02-2024 16:05
    It looks like you need to go into the domains application to add your new department value.
    Start in your test / dev or similar version to make sure this works before doing the same in production:
    Click on the field first, and then use Alt+F1 to find the field name.
    Go to Database Configuration and look up the field for the object based on the above result.
    Confirm the 'Domain' that you want to edit
    Navigate to the Domains application, filter for the Domain that was identified, and add your value and description there
    Make sure it shows up in the application and is selectable
    IBM Champion 2024
  • 3.  RE: Update Owning Department (creating location)
    Posted 07-03-2024 08:11
    Christopher,
    Thank you for the help, I was able to get it working.
    Thanks again,
    Zach
    Zachery Cooley
    Danfoss
