  • 1.  Load Failure Hierarchy to MAS 8.8
    Posted 09-02-2022 02:26
    Dear all,
    May I know anyway I can upload failure hierarchy in MAS 8 via MxLoader?
    Seems nextgen version doesn't support failure hierarchy, and I cannot connect legacy version to MAS.
    Many Thanks.
    Best Regards,
    Eric
    Eric Tse
    Lexco Ltd
  • 2.  RE: Load Failure Hierarchy to MAS 8.8
    Posted 09-05-2022 09:32
    Hi Eric
    I had the same issue recently, I resolved by loading the required hierarchy into a 7.6 environment using the legacy version then exporting that hierarchy with the latest version of MxLoader, this gives you the correct PARENT attribute values for the FAILURELIST object. Then load that into your MAS environment, assuming you are loading into an empty environment the first FAILURELIST value generated in the db should be 2 and this should match up with the PARENT values you exported from the 7.6 environment to maintain the same hierarchy.
    I appreciate you may not have the additional 7.6 environment but that was the easiest way to resolve that I could think of. The other potential solution is an automation script on an inbound MIF FAILURELIST message which picks up the FAILURELIST id for the failurecode in the message and uses that to populate the PARENT field.
    Hope this helps, Phil
    Phil Naylor
    MACS EU
  • 3.  RE: Load Failure Hierarchy to MAS 8.8
    Posted 04-28-2025 15:46
    The primary problem I have identified in MAS 9 at least is that the FAILURELIST id value cannot be overridden (set as restricted and locked) and is forced to the sequence value that MAS wishes to use so you have no control over it and then that affects the PARENT values. So, you are unable to get a hierarchy to go in with fixed values.
    I have reported this as a Defect with IBM Support and waiting to see what they say. Otherwise I guess it may need to be a RFE. Request for Enhancement. I also tried to use Application Export and Import and REST API and nothing will work without control on the MBO field.
    David Miller
  • 4.  RE: Load Failure Hierarchy to MAS 8.8
    Posted 04-07-2026 12:03
    In this post I have described my own approach to load failure hierarchy in MAS Manage with the latest version of MxLoader.
    Regards
    Bruno Portaluri (MaximoDev)
  • 5.  RE: Load Failure Hierarchy to MAS 8.8
    Posted 05-08-2026 07:35
    Hello Bruno.  Thanks for the update.  Tested loading data and works well.  One question though.  I am trying to export the hierarchy via the "Assets - Failure Hierarchy (custom)" sheet which uses the "MXL_FAILURELIST" object structure and am getting an error message "Sorry but loading failure hierarchy is not supported in MXLoader NextGen" with one of your URL's at then end.  The type of transaction is set to "Query" so I am not quite sure what's happening, could you shed any light on what may be happening ? Thanks
    Nigel Henderson
    Xenosys
