URGENT!!!! Maximo WORKFLOW Condition Node Logic
  • 1.  URGENT!!!! Maximo WORKFLOW Condition Node Logic
    Posted 10-28-2022 16:03
    Hi Everyone,
    Please help me with below query.
    I have workflow with condition node where it contains the method name with 3 parameters.
    Example like below,
    filenet_getexrate(:fromcurrency, :tocurrency, :statusdate)
    Basically this method is trying to get the exchange rate and used in the SQL expression of workflow condition node.
    Here my question is whether it's a stored procedure/function/trigger in data base.
    I'm basically using Oracle database and tried to list all the existing stored procedures/functions/triggers but I could not locate anything for above name.
    I have also searched for automation scripts and formulas but no luck.
    Is it a method from some Java class ? I don't think so as there is no class associated for the condition node.
    What else it could be ???
    I might be missing something here or may not have complete DB access to locate this?
    Please help in identifying origin of this logic.
    Channakeshava Gode
