  • 1.  Want to change the start center order
    Posted 02-13-2026 12:58
    Hello All,
    I am looking to sort/arrange the start center's for a user, if a user has access to 1,2,3,4,5 start center templates, currently it is displaying 1,4,2,5,2 like that, but user want to see them as 1,2,3,4,5 order.
    Need your inputs on this how to set or is there any way we can achieve it?
    Venkat
    Venkata Achanta
    CCSI
  • 2.  RE: Want to change the start center order
    Posted 02-13-2026 16:26
    Edited by Allan Henle 02-17-2026 08:18
    Hi Venkata,
    Start Centers display based off of two different criteria. First if a user has a default Start Center that will also take position 1. After the default, the start center is displayed based on the Description of the Start Center Ascending(Which is the same as Alphabetical). For example, if you have Start Centers A, B, C, D, and E, they would display in that order, however, if you have D as your default it would be in this order. D, A, B, C, E.
    You are always able to go into a Start Center Template and modify the Description so that it will correctly display. However, once you have modified the start centers you will need users to go in and update their Start Centers also.
    Allan Henle
  • 3.  RE: Want to change the start center order
    Posted 02-16-2026 18:12
    Hi Venkat
    Just to visualise.  This is the before.
    This is the after.
    This is the change that was made.  Specifically, I added a number in front of the description.
    Principal Consultant
    COSOL
    #IBMChampion
  • 4.  RE: Want to change the start center order
    Posted 02-17-2026 08:32
    Thank you for the reply Craig, this helped.
    Venkata Achanta
    CCSI
  • 5.  RE: Want to change the start center order
    Posted 02-17-2026 10:15
    The start center order is changed, but if i want to apply these changes to all users (without updating their SC) ,can we do that using any sql's? to clean up existing configurations in dependent tables? like scconfig,layout etc?
    Venkata Achanta
    CCSI
  • 6.  RE: Want to change the start center order
    Posted 02-17-2026 18:24
    Venkata,
    The only supported out-of-the-box way to update the Start Centers is for users to update them. I believe it is possible through SQL using the SCCONFIG and corresponding tables; however, I have never done this, so I do not have any SQL I can share. This is also not a supported way to do it.
    Allan Henle
