What are easy methods to calculate app points for maximo 7.6
  • 1.  What are easy methods to calculate app points for maximo 7.6
    Posted 11-05-2024 05:06
    What are easy methods to calculate app points for maximo 7.6.
    Kaiser Jamal
    Arsal
  • 2.  RE: What are easy methods to calculate app points for maximo 7.6
    Posted 11-12-2024 14:09
    IBM is providing a tool to help calculate AppPoints. You have to implement it to your maximo 7.6 ear file. You should contact IBM or the company that sells you your app points. They can certainly answer your questions. Once installed, the application will tell you, each day, your daily peak in app point consumption.
    Hope it answered your question.
    Danny
    Danny Cordeau
    Universite de Sherbrooke
  • 3.  RE: What are easy methods to calculate app points for maximo 7.6
    Posted 11-17-2024 10:01
    Kaiser, I have an SQL query written for both SQL Server and Oracle that calculates app points requirements based on peak concurrent users.
    Let me know if you are interested in hearing more about it, happy to share with you.
    regards,
    Stephen Hume
    Sheffield Scientific LLC
  • 4.  RE: What are easy methods to calculate app points for maximo 7.6
    Posted 09-26-2025 12:01
    Hi, can you send the SQL Server Script to anilcb@gmail.com
    Anil Bhagwatsaran
    Bluewaters Products Limited
  • 5.  RE: What are easy methods to calculate app points for maximo 7.6
    Posted 02-23-2026 08:35
    Hi Stephen, Could you please share with SQL if that's ok. Thanks for the support.
    Email: raj.rubin@gmail.com
    Rajkumar Selvaraj
  • 6.  RE: What are easy methods to calculate app points for maximo 7.6
    Posted 02-24-2026 09:16
    Hi Stephen,
    If you could share that to appulivelink@gmail.com that would be wonderful :)
    Appu nair
    APPECM
  • 7.  RE: What are easy methods to calculate app points for maximo 7.6
    Posted 02-25-2026 09:40
    Stephen,
    Could you please send me a copy of your SQL script  for SQL Server?
    Jim
    Jim Robb
    Axient Corp.
  • 8.  RE: What are easy methods to calculate app points for maximo 7.6
    Posted 02-24-2026 22:38
    Hi , Here is high level approach for SQL considering DB2. You may get started from the same.
    MAS : Estimating MAS AppPoints Using current Maximo 7.6 DB2 – A Complete SQL-Based Approach
    Prashant Bavane
    Principal Architect
  • 9.  RE: What are easy methods to calculate app points for maximo 7.6
    Posted 02-25-2026 08:28
    IBM or your IBM Business Partner have a script they call the Magic Script. You should speak to your IBM Business Partner you buy your licenses from to get the script and guidance on its use.
    David Miller
  • 10.  RE: What are easy methods to calculate app points for maximo 7.6
    Posted 02-26-2026 13:05
    Yes, magic script can be used to estimate App Points, but I was advised to run that script on test env. because it is quite heavy. Script can be used for estimation if you plan to migrate to trade-up current EAM licenses to MAS appoints. For regular appoints reporting ask IBM support to provide utility mention above. Have in mind that in order to install you will need downtime.
    Have a great day!
    Chavdar Cholev
    Home
