What's the most effective way you've reduced inventory discrepancies without shutting down operations for a full physical count?
  • 1.  What's the most effective way you've reduced inventory discrepancies without shutting down operations for a full physical count?
    Posted 06-17-2026 14:32
    Many warehouses and retail businesses struggle with inventory records that don't match actual stock. Full physical counts can be disruptive, time-consuming, and expensive.
    Have cycle counts, barcode scanning, inventory audits, process improvements, or other methods helped you improve inventory accuracy?
    What worked best, and what challenges did you face along the way?
    Naga rajan
    stockount
  • 2.  RE: What's the most effective way you've reduced inventory discrepancies without shutting down operations for a full physical count?
    Posted 06-18-2026 10:56
    Hi Nagarajan,
    We've helped several organizations improve inventory accuracy and streamline reconciliation processes. In many cases, the most effective approach has been implementing barcode or QR code-based inventory management integrated with IBM Maximo's Inventory Counting applications and mobile solutions.
    The combination of mobile scanning, cycle counting, configurable workflows, and robust reporting capabilities significantly reduced discrepancies between system records and physical stock while minimizing operational disruption.
    For organizations with unique requirements, we've also seen success with custom-built utilities and reconciliation tools tailored to specific business processes, inventory types, and operating environments.
    The best solution often depends on factors such as the number of assets/items, user population, indoor vs. outdoor inventory, number of storerooms, and existing processes. I'd be happy to share additional insights or recommendations if you can provide a bit more detail about your environment.
    Prashant Dixit
    ACCENTURE
