  • 1.  Whole object readyonly ,only for a specific security group
    Posted 03-04-2024 05:42
    I have to make whole jobplan object readyonly,only for craft security group. I tried global restrictions but some fields are still editable.  I tried with condition: exists( select 1 from groupuser gu where :&username&= gu.userid and gu.groupname in(' craft'). Its not working
    How to do by any other method like automation script or the above method?
    Trisha S
    Tcs
  • 2.  RE: Whole object readyonly ,only for a specific security group
    Posted 03-04-2024 17:16
    Hi Trisha,
    If you grant only read access to your craft SG, it should be sufficient. However, if the users are still able to edit it, you should check if they are assigned to other groups, and if those groups have the permission to edit the job plans. Additionally, ensure that these groups were not marked as independent.
    Maycon Belfort
    BPD Zenith
    IBM Champion 2024
