  • 1.  Work Center Error
    Posted 08-04-2022 11:39
    We are facing issue while trying to access work center it will open the work center tab but it will navigate back to start center.
    In logs its showing you cannot login at this time not sure why its happening does anyone faced the same issue?
    #WorkCenters
    Sahil Dutta
    xyz
  • 2.  RE: Work Center Error
    Posted 08-05-2022 09:23
    Check the status of the MXINTADM user account and make sure it is ACTIVE. We seen this recently and after several weeks this is what we found the issue to be.
    Mike
    Michael Marsonet
    OSV Advisory Inc.
  • 3.  RE: Work Center Error
    Posted 08-05-2022 09:41
    Check the status of the MXINTADM account as it needs to be Active. Work Centres use OSLC and this account is required when it connects. We spent weeks troubleshooting this and this was our fix.
    Mike
    Michael Marsonet
    OSV Advisory Inc.
