Hi Prashant,
Thank you for your reply.
After further test, actually, any change in work order before removal of virtual asset, will cause the same error. Need to exit the app, and the reload the workorder.
The auto script REMOVEVIRTUALASSET replaces the java function REMOVEVIRTUALASSET which is called when click the OK button to submit the removal of virtual asset in a work order.
the error message:
BMXAA8229W - Record WORKORDER : Site=BART Work Order=20114001 has been updated by another user. Your changes have not been saved. Refresh the record and try again.
Actually we saved the change before removal. If leave the problem code empty or the problem code is not empty at the beginning, it works fine.
the full error message tree is attached.
In addition, today I commented a line of code:
newMbo.getThisMboSet().save();
teststr="B.1";
#woRemote.getThisMboSet().save(); // commented this line today, get the same error
UIContext.getCurrentContext().getWebClientSession().getCurrentApp().getResultsBean().save();
Eric
Eric Zuo
San Francisco Bay Area Rapid transit
Sent: 05-11-2023 08:33
Subject: write autoscript to replace function of Webclient java class
If the problem code in workorder is empty, and user fill in the problem code, the follow-up workorder cannot be created, cannot save. Maybe there are data errors in Problem code , but my java code works fine.
- When you say it can't be created or can't be saved. Are you getting any error on UI or in Log?
Sedin Technologies
#IBM Champion 2022
#IBM Champion 2023
