Hi All, I am on Maximo 7.6.1.3 and adding attachments on workorders. On some file types - example .docb and .html I get following error ...
BMXAA6152E - This file type cannot be printed. To attach this file type, clear the Print attached document with report if printable type? check box.
I am able to add these file types but can not set print flag. I see system property for allowed extensions but I don't see where allowed printable types are maintained within maximo. Any help would be appreciated.
Have you tried setting the mxe.report.AttachDoc.validateURL to false? This has fixed a lot of attachment issues for us.
Thanks Megan, that is a good point suggestion. However, mxe.report.AttachDoc.validateURL was already set to false.
Hi Pat,
I don't know if this applies to your situation, but you might try the instructions in this URL:
https://www.ibm.com/support/pages/bmxaa6583e-file-type-not-allowed
Hey thanks Stevie for link. I ended up creating auto script on doclinks that would control what attachments were flagged printable . This way we bypassed the error message that was causing users to re-attach all documents they tried to add even if one was a non printable.
