 Can I download a complete list of all table.column associations within Maximo?
Danny Richardson's profile image
Danny Richardson posted 09-12-2023 11:59
Is it possible to download or obtain a list of all of the table.column fields in our Maximo?  Needing it for an integration with another program.  Thank you in advance.
Phil Naylor's profile image
Phil Naylor
Hi Danny
If you navigate to System Configuration > Platform Configuration > Database configuration within your system and then select the Run Reports option from the more actions menu. You should see  a report called Database Configuration. Type the table name you wish to export in the parameter box and click on submit. This should export all the attributes via BIRT. If you just wanted the ASSET table I would type in =ASSET into the parameter box otherwise you will get all tables with ASSET in the title (ASSETATTRIBUTE, ASSETANCESTOR etc.). If you wanted multiple tables you would need to put in =ASSET,=PERSON for example.
That link you provided was just for the service providers industry solution and not for the whole of Maximo but yes if you took the where clause out and ran the sql query you should get all attributes that way as well.
Hope this helps, Phil
@Phil Naylor thank you. That did give me some information, but it's not giving me exactly what they need.  I'm having to go through each field and hit alt+i to get the table.column information for each field within certain applications.  When I ran the report you said, it did not seem to give specific relationships but more high-level, or general relationships.  Do you have an idea how I can get the information from these fields without having to click alt+i on each one within the application?  Thank you.
Phil Naylor
Hi Danny
That internal field help box doesn't show any relationship, it just shows the table and column in the database that field is displaying. Relationships are held in a different table in Maximo , the MAXRELATIONSHIP table. You can view and download them via the Relationships tab when viewing an Object record in the Database Configuration module or view/extract them via SQL using (for example just the ASSET table):
select * from maxrelationship where parent = 'ASSET';
It's important to note the relationships are generally between objects themselves and not the fields directly though the relationship uses specific attributes (columns) to create that relationship. You also have the option of creating an Entity Relationship Diagram (ERD) - IBM link is below on how to do this. This may be what you are looking for, they are used when building customisations or integrations.
How to Generate an Entity Relationship (ERD) Document for Maximo (ibm.com)
Kind Regards
Phil
Sid Ogden's profile image
Sid Ogden
If all you want is a list of objects and their attributes, that document you linked gets you close. I'd use an sql tool and run the following to get this information:
select objectname, attributename from maxattribute
order by objectname, attributename;
If you need other information, for example attribute type and length, add those to the query. Something like:
select objectname, attributename, length, maxtype from maxattribute
Hope this helps.
Bruno Portaluri's profile image
Bruno Portaluri
You can use MxLoader to achieve that. Here is an example I have on my disk.
@Phil Naylor Thank you so much.  Do I need an SQL tool connected to Maximo to run that query or can I run it directly within Maximo?  I tried copying and pasting that into the Where Clause and it wouldn't work so I don't think I'm doing it right.
We do have an ERD created already, so thank you for that information.
@Bruno Portaluri  I would like to first say, thank you so much sir for such an amazing tool.  It has been a HUGE time saver for tedious, repetitive tasks, and has freed me up to be able to focus on how to better help the company instead of just typing in repeated information hundreds of times.
I was able to recreate the sheet in MX Loader from your image, thank you.  My question would be, is there a way to view the combined relationships like in the picture when it says "Table.Column" for an Object Name like "WORKORDER"?
