Hi @Robert Goff! Does the material you are using require inspection? Have you tried one that doesn't want inspection? Have you tried a PO for stock?
I give you some ideas to try:
- Check if the material you are using requires inspection.
- Create a new ITEM and do not check "Requires inspection", add it to the warehouse and do the same test with a new ITEM. It is used to know if the problem is in the master data (ITEM, INVENTORY)
- Use and old ITEM that does not require inspection. It is to know if the problem is the inspection status.
- Replicates the PO, but with stock material, not direct dispatch. It is to know if the problem is in the direct dispatch type
- Try creating another new WO, change status to APR or INPRG and use it to assume direct dispatch. To know if the problem is in the WO
Let me know.
