Depending on the Application, I want to be able to change the checkbox value for the 'Add document to the document library for others to use' checkbox on the 'Create File Attachment' dialog.
<checkbox dataattribute="show" id="spaddnewattachments_file_2_row3_col1_1_1" label="Add document to the document library for others to use" sigoption="MANAGELIB" sigoptiondatasrc="MAINRECORD"/>
Doing automation script with Object Launch Point does not work.
if ....
mbo.setValue("show",True)
Any help would be appreciate.
On which MBO are you firing this automation script and also which event?
