Hi, I have the same problem for a client currently. I have added the following idea on the portal, I couldn't find anything already created.
https://ibm-ai-apps.ideas.ibm.com/ideas/MASM-I-1313
I have a slight work around but its still far from ideal, here are the steps:
- Set the mxe.wogen.FormatCronTaskEmail to 1. - This property will add a little order to the output of the log and categorise the messages.
- Change the SQL for the WO Generation Where Clause against the org, only consider PMs that have an internal status of ACTIVE, or similar as per client reqs.
- Change the NotDueOrNotInSeason message via the DBConfig app, currently its classed as an error, change this to a warning it'll then appear in a different category on the generated log.
The above steps make the output more like this (cut down for readability), the legitimate errors appear at the top of the email:
EXTERNAL - This email is from an external source, please exercise caution when accessing links or files.
Server name: localhost:7001/MXServer
CronTask name and instance: PMWoGenCronTask.PMGEN
Start date and time: 2025-02-04T11:50:48+00:00
PMs with problems
BMXAA3212E - Error while generating work order for PM 2138. BMXAA3186E - The asset or location associated with PM 2138 has a status of FUTURE. Change the status to an Active status to generate work orders.
BMXAA3212E - Error while generating work order for PM 2132. BMXAA3186E - The asset or location associated with PM 2132 has a status of FUTURE. Change the status to an Active status to generate work orders.
BMXAA3212E - Error while generating work order for PM 2258. BMXAA3186E - The asset or location associated with PM 2258 has a status of FUTURE. Change the status to an Active status to generate work orders.
BMXAA3212E - Error while generating work order for PM 2252. BMXAA3186E - The asset or location associated with PM 2252 has a status of FUTURE. Change the status to an Active status to generate work orders.
BMXAA3212E - Error while generating work order for PM 2378. BMXAA3186E - The asset or location associated with PM 2378 has a status of FUTURE. Change the status to an Active status to generate work orders.
BMXAA3212E - Error while generating work order for PM 2372. BMXAA3186E - The asset or location associated with PM 2372 has a status of FUTURE. Change the status to an Active status to generate work orders.
BMXAA3212E - Error while generating work order for PM 2492. BMXAA3186E - The asset or location associated with PM 2492 has a status of FUTURE. Change the status to an Active status to generate work orders.
BMXAA3212E - Error while generating work order for PM 2498. BMXAA3186E - The asset or location associated with PM 2498 has a status of FUTURE. Change the status to an Active status to generate work orders.
BMXAA3212E - Error while generating work order for PM 2534. BMXAA4512E - The job plan for Job Plan JP1000 cannot be copied. BMXAA4191E - The value TUTAUDIT is not valid for Inspection Form. Specify a valid value for Inspection Form.
BMXAA3212E - Error while generating work order for PM 1775. BMXAA3186E - The asset or location associated with PM 1775 has a status of FUTURE. Change the status to an Active status to generate work orders.
BMXAA3212E - Error while generating work order for PM 1781. BMXAA4512E - The job plan for Job Plan JP1000 cannot be copied. BMXAA4191E - The value TUTAUDIT is not valid for Inspection Form. Specify a valid value for Inspection Form.
BMXAA3212E - Error while generating work order for PM 1889. BMXAA4512E - The job plan for Job Plan JP1000 cannot be copied. BMXAA4191E - The value TUTAUDIT is not valid for Inspection Form. Specify a valid value for Inspection Form.
BMXAA3212E - Error while generating work order for PM 1890. BMXAA4512E - The job plan for Job Plan JP1000 cannot be copied. BMXAA4191E - The value TUTAUDIT is not valid for Inspection Form. Specify a valid value for Inspection Form.
BMXAA3212E - Error while generating work order for PM 1971. BMXAA4512E - The job plan for Job Plan JP1000 cannot be copied. BMXAA4191E - The value TUTAUDIT is not valid for Inspection Form. Specify a valid value for Inspection Form.
PMs that generated successfully
BMXAA3191W - PM 2123 is not due yet, or it does not fall within the active season.
BMXAA3191W - PM 2097 is not due yet, or it does not fall within the active season.
BMXAA3191W - PM 2098 is not due yet, or it does not fall within the active season.
BMXAA3191W - PM 2099 is not due yet, or it does not fall within the active season.
BMXAA3191W - PM 2101 is not due yet, or it does not fall within the active season.
BMXAA3191W - PM 2102 is not due yet, or it does not fall within the active season.
BMXAA3191W - PM 2103 is not due yet, or it does not fall within the active season.
BMXAA3191W - PM 2104 is not due yet, or it does not fall within the active season.
