Hi Experts,
We ran into an error below during installation of MAS Manage using ansible script playbook
Error text captured below:
An exception occurred during task execution. To see the full traceback, use -vvv. The error was: ansible_collections.kubernetes.core.plugins.module_utils.k8s.exceptions.CoreException: Failed to gather information about ManageWorkspace(s) even after waiting for 120 seconds
fatal: [localhost]: FAILED! => {"attempts": 60, "changed": false, "msg": "Failed to gather information about ManageWorkspace(s) even after waiting for 120 seconds"}
Ansible scripts used:
export MAS_APP_ID=manage
export MAS_ANNOTATIONS=mas.ibm.com/operationalMode=nonproduction
export MAS_CONFIG_DIR=~/masconfig
export MAS_WORKSPACE_ID=mas9qa
export MAS_WORKSPACE_NAME=mas9qa
export MAS_INSTANCE_ID=mas9qa
export DB2_DBNAME=BLUDB
export DB2_INSTANCE_NAME=mas9qa
export MAS_APPWS_COMPONENTS="base=latest"
export ENFORCE_DB2_CONFIG=True
export DB2_ENTITLEMENT_KEY=xxx
export MAS_ENTITLEMENT_KEY=xxx
export IBM_ENTITLEMENT_KEY=xxx
export DB2_META_STORAGE_ACCESSMODE=ReadWriteOnce
export DB2_META_STORAGE_SIZE=20Gi
export DB2_META_STORAGE_CLASS=gp3-csi
export DB2_DATA_STORAGE_ACCESSMODE=ReadWriteOnce
export DB2_DATA_STORAGE_SIZE=100Gi
export DB2_DATA_STORAGE_CLASS=gp3-csi
export DB2_BACKUP_STORAGE_ACCESSMODE=ReadWriteOnce
export DB2_BACKUP_STORAGE_SIZE=100Gi
export DB2_BACKUP_STORAGE_CLASS=gp3-csi
export DB2_CPU_REQUESTS=4000m
export DB2_CPU_LIMITS=6000m
export DB2_MEMORY_REQUESTS=32Gi
export DB2_MEMORY_LIMITS=64Gi
export DB2_LOGS_STORAGE_ACCESSMODE=ReadWriteOnce
export DB2_LOGS_STORAGE_CLASS=gp3-csi
export DB2_LOGS_STORAGE_SIZE=100Gi
export DB2_TEMP_STORAGE_ACCESSMODE=ReadWriteOnce
export DB2_TEMP_STORAGE_SIZE=100Gi
export DB2_TEMP_STORAGE_CLASS=gp3-csi
export KUBECONFIG=/home/ec2-user/openshift/installer/auth/kubeconfig
export MAS_APP_UPGRADE_STRATEGY=Manual
oc login --token=xxx --server=xxx
ansible-playbook ibm.mas_devops.oneclick_add_manage
Per checking the MAS manage workspace an error is shown below:
Please advise on error encountered or if missed something from script above
