 Error in SystemErr.log - Can someone validate CREATESR app XML file for me please?
Danny Cordeau's profile image
Danny Cordeau posted 07-15-2025 13:28
Good afternoon!
7.6.1.3 here!
I have an error in my SystemErr.log file:
[15/07/25 13:01:33:524 EDT] 0000e635 SystemErr     R psdi.util.MXApplicationException: BMXAA4176E - Attribute ORDID does not exist. Gather the logs from the <HOME> directory and determine the process or app referencing the invalid attribute.
I search for that attribute and I think I found it! In Application Designer, if I export CREATESR application, I see this in the XML file :
Can someone confirm me that instead of "ordid", I should see "orgid"? It is a simple question yes, but all my Maximo instances have the same value and I just want to be sure.
Thanks in advance!
Have a nice day!
Danny
There are no default value controls in the out of the box application. Someone added these for your environments and made a typo on the ORGID piece. With a default on SITEID, you shouldn't need one on ORGID so you could probably remove it entirely.
Danny Cordeau
Thanks Steven for your input! I will try to make the correction and/or remove the orgid default value.
Have a nice day!
