Hi Brett Coleman,
Thanks for you attention. After discuss with IBM and an OpenShift specialist, I had discovered that this problem and others are related to a low latency between my cluster and the disc. It was something like 97 ms and this is not a good number for an OpenShift Cluster or Single Node installation.
The infraestructure team will adjust the hardware and I will try later.
Thanks again!
Leonardo Lima.
