Hi Everyone,
In one of my Windows VM, i'm trying to connect existing Maximo (with oracle DB) to MSSQL DB (version 13 Express Edition).
I have followed IBM documentation to configure MSSQL server manually.
When I execute Maxinst.bat, Updatedb.bat, configDb.bat, encryptproprties.bat, it gets connected to MSSQL DB fine and executes these commands.
But when I rebuild and deploy the ear into websphere, maximo is failing to connect to DB with "SQL Server did not return a response. The connection has been closed" error.
Any advice, please?
Im using this driver in maximo.properties file.
mxe.db.driver=com.microsoft.sqlserver.jdbc.SQLServerDriver
Here, My Java version is 8 and I have kept all the below jar's in Maximo and Websphere lib folder.
Merlia.jar
mssql-jdbc-6.4.0.jre8.jar
mssql-jdbc-12.2.0.jre8.jar
sqljdbc.jar
sqljdbc42.jar
Error:
[4/11/23 12:47:19:435 CST] 000000a4 SystemOut O 11 Apr 2023 12:47:19:433 [ERROR] [] [] BMXAA6421E - The system could not connect to the JDBC source: jdbc:sqlserver://localhost:1433;databaseName=maxdb76;sslProtocol=TLSv1.2;encrypt=true;trustServerCertificate=trueThe driver could not establish a secure connection to SQL Server by using Secure Sockets Layer (SSL) encryption. Error: "SQL Server did not return a response. The connection has been closed. ClientConnectionId:b9256b00-e773-478f-9bba-d938798a080e".
[4/11/23 12:47:19:439 CST] 000000a4 SystemOut O 11 Apr 2023 12:47:19:436 [ERROR] [] [] BMXAA6538E - Failed to initialize MAXIMO business object services.
psdi.util.MXSystemException: access#DBConnectFail
at psdi.server.MXServer.checkMtEnabled(MXServer.java:6395)
at psdi.server.MXServer.start(MXServer.java:3650)
at psdi.servlet.MAXIMOStartupServlet.init(MAXIMOStartupServlet.java:92)
at com.ibm.ws.webcontainer.servlet.ServletWrapper.init(ServletWrapper.java:345)
at com.ibm.ws.webcontainer.servlet.ServletWrapperImpl.init(ServletWrapperImpl.java:168)
at com.ibm.ws.webcontainer.servlet.ServletWrapper.loadOnStartupCheck(ServletWrapper.java:1369)
at com.ibm.ws.webcontainer.webapp.WebApp.doLoadOnStartupActions(WebApp.java:640)
at com.ibm.ws.webcontainer.webapp.WebApp.commonInitializationFinally(WebApp.java:606)
at com.ibm.ws.webcontainer.webapp.WebAppImpl.initialize(WebAppImpl.java:426)
at com.ibm.ws.webcontainer.webapp.WebGroupImpl.addWebApplication(WebGroupImpl.java:88)
at com.ibm.ws.webcontainer.VirtualHostImpl.addWebApplication(VirtualHostImpl.java:171)
at com.ibm.ws.webcontainer.WSWebContainer.addWebApp(WSWebContainer.java:901)
at com.ibm.ws.webcontainer.WSWebContainer.addWebApplication(WSWebContainer.java:789)
at com.ibm.ws.webcontainer.component.WebContainerImpl.install(WebContainerImpl.java:427)
at com.ibm.ws.webcontainer.component.WebContainerImpl.start(WebContainerImpl.java:719)
at com.ibm.ws.runtime.component.ApplicationMgrImpl.start(ApplicationMgrImpl.java:1211)
at com.ibm.ws.runtime.component.DeployedApplicationImpl.fireDeployedObjectStart(DeployedApplicationImpl.java:1390)
at com.ibm.ws.runtime.component.DeployedModuleImpl.start(DeployedModuleImpl.java:639)
at com.ibm.ws.runtime.component.DeployedApplicationImpl.start(DeployedApplicationImpl.java:979)
at com.ibm.ws.runtime.component.ApplicationMgrImpl.startApplication(ApplicationMgrImpl.java:795)
at com.ibm.ws.runtime.component.ApplicationMgrImpl.startApplicationDynamically(ApplicationMgrImpl.java:1413)
at com.ibm.ws.runtime.component.ApplicationMgrImpl.start(ApplicationMgrImpl.java:2273)
at com.ibm.ws.runtime.component.CompositionUnitMgrImpl.start(CompositionUnitMgrImpl.java:436)
at com.ibm.ws.runtime.component.CompositionUnitImpl.start(CompositionUnitImpl.java:123)
at com.ibm.ws.runtime.component.CompositionUnitMgrImpl.start(CompositionUnitMgrImpl.java:379)
at com.ibm.ws.runtime.component.CompositionUnitMgrImpl.access$500(CompositionUnitMgrImpl.java:127)
at com.ibm.ws.runtime.component.CompositionUnitMgrImpl$1.run(CompositionUnitMgrImpl.java:654)
at com.ibm.ws.security.auth.ContextManagerImpl.runAs(ContextManagerImpl.java:5464)
at com.ibm.ws.security.auth.ContextManagerImpl.runAsSystem(ContextManagerImpl.java:5680)
at com.ibm.ws.security.core.SecurityContext.runAsSystem(SecurityContext.java:255)
at com.ibm.ws.runtime.component.CompositionUnitMgrImpl.startCompositionUnit(CompositionUnitMgrImpl.java:668)
at com.ibm.ws.runtime.component.CompositionUnitMgrImpl.startCompositionUnit(CompositionUnitMgrImpl.java:612)
at com.ibm.ws.runtime.component.ApplicationMgrImpl.startApplication(ApplicationMgrImpl.java:1303)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:95)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:55)
at java.lang.reflect.Method.invoke(Method.java:508)
at sun.reflect.misc.Trampoline.invoke(MethodUtil.java:83)
at sun.reflect.misc.MethodUtil.invoke(MethodUtil.java:287)
at javax.management.modelmbean.RequiredModelMBean$4.run(RequiredModelMBean.java:1263)
at java.security.AccessController.doPrivileged(AccessController.java:620)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:87)
at javax.management.modelmbean.RequiredModelMBean.invokeMethod(RequiredModelMBean.java:1257)
at javax.management.modelmbean.RequiredModelMBean.invoke(RequiredModelMBean.java:1096)
at com.sun.jmx.interceptor.DefaultMBeanServerInterceptor.invoke(DefaultMBeanServerInterceptor.java:831)
at com.sun.jmx.mbeanserver.JmxMBeanServer.invoke(JmxMBeanServer.java:813)
at com.ibm.ws.management.AdminServiceImpl$1.run(AdminServiceImpl.java:1350)
at com.ibm.ws.security.util.AccessController.doPrivileged(AccessController.java:118)
at com.ibm.ws.management.AdminServiceImpl.invoke(AdminServiceImpl.java:1243)
at com.ibm.ws.management.application.sync.StartDeploymentTask.startDeployment(StartDeploymentTask.java:249)
at com.ibm.ws.management.application.sync.StartDeploymentTask.fullAppUpdate(StartDeploymentTask.java:121)
at com.ibm.ws.management.application.sync.StartDeploymentTask.performTask(StartDeploymentTask.java:109)
at com.ibm.ws.management.application.sync.AppBinaryProcessor$ExpandApp.expand(AppBinaryProcessor.java:1734)
at com.ibm.ws.management.application.sync.AppBinaryProcessor.postProcessSynchronousExt(AppBinaryProcessor.java:774)
at com.ibm.ws.management.bla.sync.BLABinaryProcessor.postProcess(BLABinaryProcessor.java:599)
at com.ibm.ws.management.bla.sync.BLABinaryProcessor.onChangeCompletion(BLABinaryProcessor.java:476)
at com.ibm.ws.management.bla.sync.BinaryProcessorWrapper.onChangeCompletion(BinaryProcessorWrapper.java:109)
at com.ibm.ws.management.repository.FileRepository.postNotify(FileRepository.java:1938)
at com.ibm.ws.management.repository.FileRepository.update(FileRepository.java:1442)
at com.ibm.ws.management.repository.client.LocalConfigRepositoryClient.update(LocalConfigRepositoryClient.java:189)
at com.ibm.ws.sm.workspace.impl.WorkSpaceMasterRepositoryAdapter.update(WorkSpaceMasterRepositoryAdapter.java:667)
at com.ibm.ws.sm.workspace.impl.RepositoryContextImpl.update(RepositoryContextImpl.java:1998)
at com.ibm.ws.sm.workspace.impl.RepositoryContextImpl.synch(RepositoryContextImpl.java:1946)
at com.ibm.ws.sm.workspace.impl.WorkSpaceImpl.synch(WorkSpaceImpl.java:549)
at com.ibm.ws.console.core.action.SyncWorkSpaceAction.execute(SyncWorkSpaceAction.java:294)
at org.apache.struts.action.RequestProcessor.processActionPerform(Unknown Source)
at org.apache.struts.action.RequestProcessor.process(Unknown Source)
at org.apache.struts.action.ActionServlet.process(Unknown Source)
at org.apache.struts.action.ActionServlet.doGet(Unknown Source)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:575)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:668)
at com.ibm.ws.webcontainer.servlet.ServletWrapper.service(ServletWrapper.java:1233)
at com.ibm.ws.webcontainer.servlet.ServletWrapper.handleRequest(ServletWrapper.java:782)
at com.ibm.ws.webcontainer.servlet.ServletWrapper.handleRequest(ServletWrapper.java:481)
at com.ibm.ws.webcontainer.servlet.ServletWrapperImpl.handleRequest(ServletWrapperImpl.java:178)
at com.ibm.ws.webcontainer.filter.WebAppFilterChain.invokeTarget(WebAppFilterChain.java:136)
at com.ibm.ws.webcontainer.filter.WebAppFilterChain.doFilter(WebAppFilterChain.java:97)
at com.ibm.ws.console.core.servlet.WSCUrlFilter.setUpCommandAssistance(WSCUrlFilter.java:967)
at com.ibm.ws.console.core.servlet.WSCUrlFilter.continueStoringTaskState(WSCUrlFilter.java:514)
at com.ibm.ws.console.core.servlet.WSCUrlFilter.doFilter(WSCUrlFilter.java:335)
at com.ibm.ws.webcontainer.filter.FilterInstanceWrapper.doFilter(FilterInstanceWrapper.java:195)
at com.ibm.ws.webcontainer.filter.WebAppFilterChain.doFilter(WebAppFilterChain.java:91)
at com.ibm.ws.webcontainer.filter.WebAppFilterManager.doFilter(WebAppFilterManager.java:967)
at com.ibm.ws.webcontainer.filter.WebAppFilterManager.invokeFilters(WebAppFilterManager.java:1107)
at com.ibm.ws.webcontainer.servlet.CacheServletWrapper.handleRequest(CacheServletWrapper.java:87)
at com.ibm.ws.webcontainer.WebContainer.handleRequest(WebContainer.java:949)
at com.ibm.ws.webcontainer.WSWebContainer.handleRequest(WSWebContainer.java:1817)
at com.ibm.ws.webcontainer.channel.WCChannelLink.ready(WCChannelLink.java:200)
at com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.handleDiscrimination(HttpInboundLink.java:463)
at com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.handleNewRequest(HttpInboundLink.java:530)
at com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.processRequest(HttpInboundLink.java:316)
at com.ibm.ws.http.channel.inbound.impl.HttpICLReadCallback.complete(HttpICLReadCallback.java:88)
at com.ibm.ws.tcp.channel.impl.AioReadCompletionListener.futureCompleted(AioReadCompletionListener.java:175)
at com.ibm.io.async.AbstractAsyncFuture.invokeCallback(AbstractAsyncFuture.java:217)
at com.ibm.io.async.AsyncChannelFuture.fireCompletionActions(AsyncChannelFuture.java:161)
at com.ibm.io.async.AsyncFuture.completed(AsyncFuture.java:138)
at com.ibm.io.async.ResultHandler.complete(ResultHandler.java:204)
at com.ibm.io.async.ResultHandler.runEventProcessingLoop(ResultHandler.java:775)
at com.ibm.io.async.ResultHandler$2.run(ResultHandler.java:905)
at com.ibm.ws.util.ThreadPool$Worker.run(ThreadPool.java:1892)
Caused by: com.microsoft.sqlserver.jdbc.SQLServerException: The driver could not establish a secure connection to SQL Server by using Secure Sockets Layer (SSL) encryption. Error: "SQL Server did not return a response. The connection has been closed. ClientConnectionId:b9256b00-e773-478f-9bba-d938798a080e".
at com.microsoft.sqlserver.jdbc.SQLServerConnection.terminate(SQLServerConnection.java:3937)
at com.microsoft.sqlserver.jdbc.TDSChannel.enableSSL(IOBuffer.java:1950)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.connectHelper(SQLServerConnection.java:3456)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.login(SQLServerConnection.java:3077)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.connectInternal(SQLServerConnection.java:2919)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.connect(SQLServerConnection.java:1787)
at com.microsoft.sqlserver.jdbc.SQLServerDriver.connect(SQLServerDriver.java:1229)
at java.sql.DriverManager.getConnection(DriverManager.java:675)
at java.sql.DriverManager.getConnection(DriverManager.java:258)
at psdi.util.DBConnect.getConnection(DBConnect.java:100)
at psdi.server.MXServer.checkMtEnabled(MXServer.java:6361)
... 103 more
Caused by: java.io.IOException: SQL Server did not return a response. The connection has been closed. ClientConnectionId:b9256b00-e773-478f-9bba-d938798a080e
at com.microsoft.sqlserver.jdbc.TDSChannel$SSLHandshakeInputStream.ensureSSLPayload(IOBuffer.java:884)
at com.microsoft.sqlserver.jdbc.TDSChannel$SSLHandshakeInputStream.readInternal(IOBuffer.java:938)
at com.microsoft.sqlserver.jdbc.TDSChannel$SSLHandshakeInputStream.read(IOBuffer.java:931)
at com.microsoft.sqlserver.jdbc.TDSChannel$ProxyInputStream.readInternal(IOBuffer.java:1193)
at com.microsoft.sqlserver.jdbc.TDSChannel$ProxyInputStream.read(IOBuffer.java:1179)
at com.ibm.jsse2.a.a(a.java:79)
at com.ibm.jsse2.a.a(a.java:182)
at com.ibm.jsse2.as.a(as.java:883)
at com.ibm.jsse2.as.i(as.java:969)
at com.ibm.jsse2.as.a(as.java:680)
at com.ibm.jsse2.as.startHandshake(as.java:859)
at com.microsoft.sqlserver.jdbc.TDSChannel.enableSSL(IOBuffer.java:1839)
