 how can i add "%" sign to aggregate column
  • Mobility
  • Reporting
syed mehdi's profile image
syed mehdi posted 07-16-2023 04:42
how can i add "%" sign to aggregate column value. I concatenated but it does not display sign only values get display.
Jhonatan Jerez's profile image
Jhonatan Jerez
Hello Syed,
Can you elaborate more on your question?
If you use Eclipse to update your report file, you should see the "Format Number" option in the Properties tab. From there, you can format the display of the aggregated field.
Hopefully, this can help.
Jj
syed mehdi
Hello Jerez,
Thanks for your reply.
