@Bill Poelma Once you use the edit history action in work order tracking, view the work order history. If you have the HISTEDIT entry, then you were able to add a 'RETURN' issue type material on the Actual Materials sub-tab. Once saved, as noted, the record should return to read only, so you may need to try again.
