 Inspection forms - can you import/export?
  •   MxLoader
  • Work Centers
Matthew Reed's profile image
Matthew Reed posted 01-06-2023 11:57
Is it possible to export/import inspection forms, so you can promote them from one environment/instance (DEV/TEST/PROD) to another? If not, what's the best option, other than working in PROD at all times?
Thanks!
Enock Onsase's profile image
Enock Onsase
Yes, this is possible using migration manager, similar to other objects in Maximo.
An alternatively you could customize and use application import/export feature. See technote below for details. If your client if open for this customization, this should work for you.
How to import Inspection forms into Maximo (ibm.com)
Enock Onsase,
Genesis Solutions.
Henrik Söder's profile image
Henrik Söder
I manage to create an objectstructure and load inspectionforms using MXLoader.
But have problem to export, had to do it in 3 stages and combine in excel.
Henrik Söder
Hi!
Seems we got MXLoader to work for both Read and load now.
You need an objectstructure with Inspectionform, Inspquestion, Inspfield, Inspfieldoptions .......
And then columnheaders like:
INSPFORMNUM
NAME
DESCRIPTION_LONGDESCRIPTION
STATUS
REVISION
SITEID
ORGID
TYPE
INSPQUESTION.INSPQUESTIONNUM
INSPQUESTION.SEQUENCE
INSPQUESTION.GROUPSEQ
INSPQUESTION.DESCRIPTION
INSPFIELD.INSPFIELDNUM
INSPFIELD.REQUIRED
INSPFIELD.SEQUENCE
INSPFIELD.METERNAME
INSPFIELD.METERTYPE
INSPFIELD.FIELDTYPE
INSPFIELD.DOCTYPE
INSPFIELD.DESCRIPTION
INSPFIELD.INSPFIELDOPTION.DESCRIPTION.......
Good luck!
Venkataraman Guruswamy's profile image
You can export from backend and import using insert scripts
Matis Dovydas's profile image
Matis Dovydas
@HENRIK SÖDER Well, ok, you can make simple questions inside that inspection form with MxLoader (created similar loader), but I can't figure out how to make sub-questions, how to load that with loader? Found out that there is possible to get information from already imported forms. Columnheaders like:
INSPQUESTION.INSPFIELD.INSPFIELDOPTION.COLOR,
INSPQUESTION.INSPFIELD.INSPFIELDOPTION.DESCRIPTION,
INSPQUESTION.INSPFIELD.INSPFIELDOPTION.HASLD,
INSPQUESTION.INSPFIELD.INSPFIELDOPTION.ICON,
INSPQUESTION.INSPFIELD.INSPFIELDOPTION.LANGCODE,
INSPQUESTION.INSPFIELD.INSPFIELDOPTION.REQUIREACTION,
INSPQUESTION.INSPFIELD.INSPFIELDOPTION.SEQUENCE,
INSPQUESTION.INSPFIELD.DESCRIPTION,
INSPQUESTION.INSPFIELD.FIELDTYPE,
INSPQUESTION.INSPFIELD.LANGCODE,
INSPQUESTION.INSPFIELD.REQUIRED,
INSPQUESTION.INSPFIELD.SEQUENCE,
INSPQUESTION.INSPFIELD.VISIBLE,
INSPQUESTION.GROUPID,
INSPQUESTION.LANGCODE
I dont know how to make or update those fields. Does anyone has MxLoader object structure for this?
HENRIK SÖDER's profile image
HENRIK SÖDER
@Matis Dovydas I attached some info!
You should't update inspform if you already used them and have inspformresults, you should revise!
But if you don't have used them you can just delete using mxloader and reload with updated info.
Quite tricky with cascadeoptions due to numbers in TGT and SRC columns.
I hope this helps.
Good luck!
Jason VenHuizen's profile image
Jason VenHuizen
Our VS Code extension handles exporting and importing inspection forms, including revisioning.  It is open so if you want to look into the scripts that perform these actions you can.
Matis Dovydas
@HENRIK SÖDER Well thank you for some tips. I will try them.
I would like to say, that I made some kind of loader, but It's too big and importing/uploading takes times. Actually there is three sheets which you need to go through step by step. There is also sub questions and when you try to load all questions at once, in user interface those questions is not sorting like in groups. Than you need to go in UI and manually sort/group those questions which makes that importing annoying. Image if you have 50+ questions in one inspection form.
All the mess started when we tried to digitize thoes inspection forms from paper into IBM.
Matis Dovydas
Jason VenHuizen looks really advanced. I will take a look at this one too. Thank you for reply. 👀
Jason VenHuizen
I should also add that there is a companion command line tool for the VS Code extension that can be used in a code pipeline to automated deployments.  Hope that is helpful.
https://www.npmjs.com/package/maximo-dev-tools
