I'm facing this issue during Manage 9.0.5 installation, I'm following the MAS DevOps Ansible Collection using Manage playbook installation usinf an external sql Database ,
export MAS_INSTANCE_ID=inst1
export MAS_CONFIG_DIR=~/masconfig
export IBM_ENTITLEMENT_KEY=xxx
export CONFIGURE_EXTERNAL_DB=true
export DB_INSTANCE_ID=maxdbxx
export MAS_JDBC_USER=maximo
export MAS_JDBC_PASSWORD=xxx
export MAS_JDBC_URL=xxx
export MAS_APP_SETTINGS_DB_SCHEMA=maximo
export MAS_APP_SETTINGS_TABLESPACE=maxdata
export MAS_APP_SETTINGS_INDEXSPACE=maxindex
unfortunately i get this error during the maxinst process
com.microsoft.sqlserver.jdbc.SQLServerException: Invalid filegroup 'MAXDATA' specified.
2188at com.microsoft.sqlserver.jdbc.SQLServerException.makeFromDatabaseError(SQLServerException.java:261)
2189at com.microsoft.sqlserver.jdbc.SQLServerStatement.getNextResult(SQLServerStatement.java:1752)
2190at com.microsoft.sqlserver.jdbc.SQLServerStatement.doExecuteStatement(SQLServerStatement.java:946)
2191at com.microsoft.sqlserver.jdbc.SQLServerStatement$StmtExecCmd.doExecute(SQLServerStatement.java:840)
2192at com.microsoft.sqlserver.jdbc.TDSCommand.execute(IOBuffer.java:7739)
2193at com.microsoft.sqlserver.jdbc.SQLServerConnection.executeCommand(SQLServerConnection.java:4384)
2194at com.microsoft.sqlserver.jdbc.SQLServerStatement.executeCommand(SQLServerStatement.java:293)
2195at com.microsoft.sqlserver.jdbc.SQLServerStatement.executeStatement(SQLServerStatement.java:263)
2196at com.microsoft.sqlserver.jdbc.SQLServerStatement.execute(SQLServerStatement.java:813)
2197at psdi.configure.Maxinst.doSql(Maxinst.java:2370)
2198at psdi.configure.Maxinst.doOneUnlcvtLine(Maxinst.java:636)
2199at psdi.configure.Maxinst.doUnlcvtSql(Maxinst.java:499)
2200at psdi.configure.Maxinst.process(Maxinst.java:414)
2201at psdi.configure.Maxinst.main(Maxinst.java:2847)
2202Invalid filegroup 'MAXDATA' specified. Wed Dec 18 20:58:50 GMT 2024
2203Invalid filegroup 'MAXDATA' specified. Wed Dec 18 20:58:50 GMT 2024
2204BMXAA6819I - Maxinst completed with errors. Wed Dec 18 20:58:50 GMT 2024
I've created a MAXDATA file group manually on the DB and then I get this other message and I can see that tables are being rated but then I got this message:
The filegroup "MAXDATA" has no files assigned to it,
Have any one experienced this issue?
