 Is There a Way to Transfer/Move Rotating Assets from One Organization to Another?
Jump to  Best Answer
  • End User
  • Work Management
Toni Fields's profile image
Toni Fields posted 08-10-2023 10:24
I have tried many methods to complete this, but I feel like I am missing something. I have a rotating asset in a storeroom in one organization that needs to be transferred/moved to a storeroom in another organization. Any help is greatly appreciated.
Steven Shull  Best Answer
Are the two organizations sharing the same itemset? If they are not sharing an ITEMSET it is not possible. If they are using the same item set, there are some MAXVAR settings that dictate whether a PO is required for internal transfers across organizations (or sites). Go to the Organization application and open each Organization. Under the Inventory Options choose Transfer Options.
A shipment is always required across organizations. A PO is not required by default but can be made required for a transfer across Organizations.
Assuming a PO is not required, you should be able to create an inventory usage record with the from site & storeroom matching the originating storeroom. On the line set the desired target site and storeroom. You will need security access to both the originating and destination site and storeroom to do this. Change the inventory usage to SHIPPED which will enable you to create a shipment. Then in the Shipment Receiving go through the process of receiving the shipment.
Toni Fields
Steven,
Thanks for the response. When you responded, I was actually researching the Shipment Receiving application. They are indeed sharing the same itemset and both do allow transfer across organizations. With the information that you have given, I can cross the finish line. Thanks again.
