 JSON Mapping and literals/constants in MAS 9.1
  • Integrations
Karla Foster's profile image
Karla Foster posted 01-13-2026 15:56
I am looking for some much-needed help.  We have an active integration that is working today.  I simply need to change the literal/constant value for a given Target.  I want to change the value for BookID from "Main" to "NEW".  The UI seems to force me to choose an attribute but clearly, a literal is successful currently.  I have SYSADMIN level security and am not receiving an error.  It just won't accept a new value.  This feels like I am missing something basic.  Any help would be greatly appreciated.
Greg Tsarev's profile image
Greg Tsarev
Hi Karla, have you tried deleting the property completely and recreating it with the new value? By default, you should be able to enter anything you want in the source attribute for outbound mapping, including static values. If the problem persists, and the behavior that you're seeing is that the value gets flipped back to "Main" as soon as you change it and tab out, without getting any errors or warnings, I would recommend to make sure that there are no automation scripts that could be interfering and potentially overwriting the value.
