 Login issue - cannot login at this time
  • End User
danny mohar's profile image
danny mohar posted 06-20-2023 20:59
I've seen this issue recently where a user receives this message when trying to login.
BMXAA7901E - You cannot log in at this time.  Contact the system administrator.
Any suggested solutions ?
mark robbins's profile image
mark robbins
You need to look at the JVM logs to see what is happening.
there could be a problem with the system.
My blog article discusses where to find the SystemOut.log file
http://www.linkedin.com/pulse/introduction-most-important-maximo-log-file-mark-robbins
if you haven't worked through the logs before then reach out to me privately and I can give the logs a quick look
Dragos Chitu's profile image
Dragos Chitu
It might sound childish, but without having addl info from your side I have to ask this: have you checked that the user is still Active?
Dragos
danny mohar
There was an underlying issue with the userid.   What was displayed thru maximo front end was different to the underlying data at SQL level.   This was confirmed with SQL query against the access table.   The userid was then adjusted to suit.
