 Maximo Application Framework error when first connect - You are not authorized to configure any application
  • Customizations
  • Mobility
Pat Galloway's profile image
Pat Galloway posted 08-15-2024 10:01
Hello
Maximo Mobile 9.0.0 on Maximo 7.6.1.3.  New to product and first time connect MAF  to Maximo I get message "You are not authorized to configure any applications"   - I have granted login user access to OSLCMAFAPPDATA and MXAPIWPEDITSETTING object structures.  Any suggestions?  Thanks in advance!
Pat Galloway
Resolved - issue seems to have been with the run docker command -  changed .workspace to xx...
old:
docker run -it --privileged --env NODE_TLS_REJECT_UNAUTHORIZED=0 -p 3001:3001 -p 3006:3006 -v /dockertest1/dt1:/graphite/.worksplace -it icr.io/cpopen/maf-tools:9.0.0
new
docker run -it --privileged --env NODE_TLS_REJECT_UNAUTHORIZED=0 -p 3001:3001 -p 3006:3006 -v /dockertest1/dt1:/graphite/xx -it icr.io/cpopen/maf-tools:9.0.0
