  • 1.  SQL to obtain YTD Labor Hrs and YTD Cost per Asset
    Posted 01-03-2024 10:33
    Hello all, I have now been set up with an SQL tool to run database queries.
    • Is it possible to run an SQL that will give me the YTD Labor Hours for an asset?
    • Also the YTD Material Cost?
    Thank you
    #Analytics
  • 2.  RE: SQL to obtain YTD Labor Hrs and YTD Cost per Asset
    Posted 01-04-2024 08:53
    I am not sure on your maximo version but in maximo 7.6.1.3 ASSETROLLUPSTATUS table can help you get those cost details by preparing SQL summing up respective cost against all WO's for the asset.
    Prashant B
  • 3.  RE: SQL to obtain YTD Labor Hrs and YTD Cost per Asset
    Posted 01-04-2024 10:20
    Hello @Prashant Bavane.  My Maximo version is 7.6.1.2
    Thank you
  • 4.  RE: SQL to obtain YTD Labor Hrs and YTD Cost per Asset
    Posted 01-04-2024 14:32
    Hi @Danny Richardson
    Good Day, I tried the following approach to get the labor and material details: Since every work order is raised on an asset, to perform that maintenance activity, we need some material, which is tracked in MATUSETRANS, and labor transactions, which are tracked in the LABTRANS table. In Maximo, each table holds the asset number attribute. On that basis, I have prepared a script that gives the YTD cost and labor hours.
    SELECT W.ASSETNUM,SUM(COALESCE(L.REGULARHRS ,0)) AS "tOTAL lABOR HOUR",
    SUM((COALESCE(M.ACTUALCOST ,0))+(COALESCE(L.LINECOST,0))) AS "TOTAL YTD COST"
    FROM WORKORDER W
    INNER JOIN LABTRANS L ON L.ASSETNUM=W.ASSETNUM
    INNER JOIN MATUSETRANS M ON M.ASSETNUM=W.ASSETNUM
    WHERE W.ASSETNUM='ASSETNUM'
    GROUP BY W.ASSETNUM
    Vivek Nagre
    JLL
  • 5.  RE: SQL to obtain YTD Labor Hrs and YTD Cost per Asset
    Posted 01-05-2024 16:20
    Thank you @Vivek Nagre.  I appreciate the detailed and thoughtful response.  I will have to review and respond on here with what I was able to achieve.  Thank you again.
  • 6.  RE: SQL to obtain YTD Labor Hrs and YTD Cost per Asset
    Posted 01-05-2024 01:34
    Edited by Prashant Sharma 01-05-2024 01:38
    If you are on old version of Maximo then you have access to 2 Reports in Asset application-
    1. Rollup Maintenance Cost
    2. Rollup. Maintenance Cost Update.
    If you run Asset Cost Rollup report, it will give you Total cost and YTD cost to be updated on the Asset. It calculates it via summing up Cost reported against CLOSED WO of Labor, Services, Tools & Material (LABTRANS, SERVRECTRANS, TOOLTRANS & MATUSETRANS).
    If you want to update the cost after review of report earlier, you can always run 2nd report of Rollup Maintenance Cost Update. Detail SQL can also be found from these reports.
    If you are at M7613 then you have select actions available for Asset Cost Rollup available.
    Sedin Technologies
    #IBM Champion 2022
    #IBM Champion 2023
  • 7.  RE: SQL to obtain YTD Labor Hrs and YTD Cost per Asset
    Thank you @Prashant Sharma.  I appreciate the detailed and thoughtful response.  I will have to review and respond on here with what I was able to achieve.  Thank you again.
  • 8.  RE: SQL to obtain YTD Labor Hrs and YTD Cost per Asset
    Posted 01-05-2024 08:47
    Hi Danny,
    It can be used as the basis, just needs tweaking.  Here's what I don't like about the SQL code supplied.
    1. It relies on the work order as the centre of all transactions and that is just not true.  There is a case to be had that an SR has been raised and that the agent starts/stops the timer or time is manually allocated to the SR.  Of course, this causes a labtrans entry (LABTRANS.TICKETID).  Please don't mistake this for raising an ACTIVITY from SR or INCIDENT as they are work order-based.
    2. The SQL has no linkage from the work order to the transaction tables i.e. labtrans.refwo, matusetrans.refwo.  I would not reference the work order at all, rather only involve the asset, labtrans and matusetrans all linked via the assetnum and siteid.
    3. It has not taken into account that you must link using the SITEID even if you have only one site.
    4. It only recognises the regular hours of work and has not factored in the premium hours (LABTRANS.PREMIUMPAYHOURS).
    5. It has forgotten that you want the YTD cost + hours.  That can be just as simple as year(transdate) = year(sysdate), though the sysdate/getdate()/current_timestamp depends on your database as well as how you get to extract the year.  I do have to mention that there is normally the transdate and actualdate, you have to decide which to use.  When using financial periods, a user can transact on say the 3rd, but have the actual date as the 30th...of the previous month.  This allows for the prior financial period to accumulate the costs in cases where the user forgets to enter the cost on the Friday and chooses to do it on the following Monday.
    Asset cost rollup
    As pointed out there is the table ASSETROLLUPSTATUS.  I would also like to converse about the YTD figures as these used to get populated whenever someone ran the Asset Cost Rollup report and now there is a System Property that can be enabled to automatically add the YTD that you see on the asset.  However, I need to point out that unless you are running 'something' that runs the Zero YTD menu action (also on Labor and Inventory) it only means that the cost is from when it was last reset.  So be mindful if you're looking at that figure.
    Cosol
    #IBMCahmpion
  • 9.  RE: SQL to obtain YTD Labor Hrs and YTD Cost per Asset
    Posted 01-05-2024 16:21
    Thank you @Craig Kokay for such detailed, thought-out information.  I will have to see what results I can achieve and try to respond here later with the results.
