  • 1.  Adding more fields to Item Master
    Posted 05-17-2024 15:06
    Good day.
    I wish to add more information regarding a type of inventory that we warehouse.
    We stock a great number of fuses. I may wish to add a secondary listing to further qualify the type of fuses.  For example, I wish to add more information to each SKU:
    a) Voltage (say 250V, 100V etc.)
    b) Amperage (2Amps, 1/16 Amp.,  etc.)
    c) Type of fuse (Glass, Cap, Blade,  Ceramic, Cartridge)
    d) Size (mini fuse, regular size, High Rupture)
    Can this information be added to the item master (i.e. Item Master/Specifications tab)?
    Much thanks
    Matthieu Pilotte
    Canada Post
  • 2.  RE: Adding more fields to Item Master
    Posted 05-18-2024 14:20
    Very much like a pump in maxdemo, a fuse classification and even sub classifications could be added with their own set of unique attributes, and then be associated with the appropriate item(s). Once the classification is on the item, the attribute values can be entered and saved.
    IBM Champion 2024
