Vincent,
The PlusC classes are (I think) for the Calibration solution and you would need that deployed to use that class / method. Creating a function that looks up an existing asset and applies some select attributes to the current asset as a template would be pretty easy and if you want an example of how to do that I can provide it.
Beyond that you could get more fancy and develop a full templating application depending on how sophisticated your requirements are.
Do you have a template already defined, do you have calibration available?
- Jason
Jason VenHuizen
Sharptree
