  • 1.  Asset Downtime
    Posted 11-23-2023 12:12
    In asset application when you delete a downtime record from Managed downtime history action, system is not recalculating downtime on Total Downtime field.
    ASSET.TOTDOWNTIME
    1. Create a new Asset -> Save
    2. More Actions - > Report Downtime - > Start (yesterday) -> End (now)
    Total downtime field is updated to 24 hours
    3. More Actions - > Report Downtime - > Start (today 10.00 AM) -> End (today 11.00 AM)
    Now Total downtime field is updated to 25 hours
    4. Go to - > More Actions - > Manage Downtime History -> Delete the record with 1 hour. Click OK.
    The Total Downtime field is not updated and remains 25 hours.
    Results: The Total Downtime field is not updated and remains 25 hours.
    Can someone help on the issue.
    Thanks in Advance
    Iswarya
    Ishwarya Soundarya
    Accenture
  • 2.  RE: Asset Downtime
    Posted 11-24-2023 02:17
    Can someone please help on this
    Ishwarya Soundarya
    Accenture
  • 3.  RE: Asset Downtime
    Posted 11-27-2023 03:46
    Can someone please help on this.
    Thanks in Advance
    Ishwarya Soundarya
    Accenture
  • 4.  RE: Asset Downtime
    Posted 11-27-2023 14:05
    Hi Ishwarya,
    What version and IFIX level of Maximo are you on? Sorry, I do not see this behaviour in the instance(s) I am working in (both 7.5 and 7.6.1).
    Are there any auto-scripts, conditions, etc that touch any of the fields involved in this process?
    Cheers,
    Matt
    Matt F
    OCWA
  • 5.  RE: Asset Downtime
    Posted 12-14-2023 11:08
    Hi Matt,
    Thanks for responding.
    We are using 7.6.1.3 version. We don't have any condition/automation script related to this.
    Also we have not face this issue before.
    Thanks in Advance
    Ishwarya Soundarya
    Accenture
  • 6.  RE: Asset Downtime
    Posted 12-30-2023 14:07
    HI @Ishwarya Soundarya
    I went through these problem statements and I faced face same issue as you described, so I didn't think it was a kind of IFIX issue.
    I tried to write a script on the MODDOWNTIMEHIST object to get the set from the asset using owner mbo as well, and then using a loop, we will calculate the sum of all the downtime hours in the ASSET.TOTDOWNTIME attribute, but it won't work.
    But if we use the manage downtime history action, the ASSET.TOTDOWNTIME attribute fetches the correct data from that MODDOWNTIMEHIST.
    Here, we only need to update the time when it's operational, so it will recalculate ASSET. TOTDOWNTIME and work as expected.
    Vivek Nagre
    JLL
