  • 1.  Automation Script error writing to S3 bucket in AWS (Red Hat) environment
    Posted 2 days ago
    I am having an issue with automation script.  It used to work fine on Prim in Maximo 7.6.1.3.  The script creates an AWARD memo (BIRT report) and attach it to Work order and saves it in DOCLINK folder.
    Now in MAS9, it's giving error writing to S3 folders in AWSs environment, any help or guidance will be great, I am new to AWS- Red Hat arena.
    here is script:
    from com.ibm.tivoli.maximo.report.birt.admin import ReportAdminServiceRemote
    from com.ibm.tivoli.maximo.report.birt.runtime import ReportParameterData
    from java.text import SimpleDateFormat
    from psdi.util.logging import MXLoggerFactory
    # var_rptname = ''
    #userinfo = mbo.getUserInfo()
    #para = ReportParameterData()
    def getDoclinksDir(myDocType):
        doctypesMboSet = MXServer.getMXServer().getMboSet("DOCTYPES", mbo.getUserInfo())
        doctypesMboSet.setWhere("DOCTYPE = " + "'" + myDocType + "'")
        doctypesMboSet.reset()
        doctypesMbo = doctypesMboSet.moveFirst();
        return doctypesMbo.getString("DEFAULTFILEPATH")
    def generateReport():
        if mbo.getString("STATUS") == 'APPR' and not mbo.isNull("glaccount") :
            sdf = SimpleDateFormat("yyyyMMddhhmmss")
            maximo= MXServer.getMXServer()
            var_rptname = ''
            var_filename ='AwardMemo'
            var_wonum = mbo.getString("WONUM")
            filepath = getDoclinksDir("AwardMemo")
            newType ='SentAward'
            var_rptname = 'FMS_PROJECT_Award_Memo.rptdesign'
            xdoclinksMboSet = mbo.getMboSet("PROJECTAWARDLINKS")
            # Relationship to DOCLINKS
            # (ownertable='WORKORDER' and ownerid=:workorderid  and doctype='InspMemo')
            filename2 = var_filename+ "-"+var_wonum+"-"+ sdf.format(maximo.getDate())
            filename3 = filepath + "/" + filename2 + ".pdf"
            para.addParameter("wonum", var_wonum)
            reportService = MXServer.getMXServer().lookup("BIRTREPORT")
            outputReport = reportService.runReport(userinfo, var_rptname, "WOTRACK", para, filename2, "pdf")
            report_file = open(filename3,"wb")
    #        report_file.write(outputReport)
    #        report_file.flush()
    #        report_file.close()
        # change the previous awardmemo to a diff doctype so that on the communication template only
        # the latest memo will be sent - template sends all Image folder
            docl = xdoclinksMboSet.moveFirst()
            if docl is not None:
                var_DOCTYPE = newType
            else:
                var_DOCTYPE = var_filename
            doclinksMboSet = mbo.getMboSet("DOCLINKS")
            doclinksMbo = doclinksMboSet.add()
            doclinksMbo.setValue("URLTYPE", "FILE")
            doclinksMbo.setValue("URLNAME", filename3)
            doclinksMbo.setValue("NEWURLNAME", filename3)
            doclinksMbo.setValue("DOCTYPE", var_DOCTYPE)
            doclinksMbo.setValue("ADDINFO", True)
            doclinksMbo.setValue("DOCUMENT", var_filename)
            doclinksMbo.setValue("DESCRIPTION", filename2)
            doclinksMboSet.save()
            clMbo =  mbo.createComm()
            clMbo.setValue('TEMPLATEID', 'PROJAWARD')
            try:
                clMbo.sendMessage()
            except:
                clMbo.setValue("ISSENDFAIL", True, mbo.NOACCESSCHECK)
    if (mbo.getString("STATUS") == 'APPR') and mbo.getString("WORKTYPE") == 'PROJECT':
        generateReport()
    Hardev Bal
    Navitas
  • 2.  RE: Automation Script error writing to S3 bucket in AWS (Red Hat) environment
    Posted 2 days ago
    Edited by Steven Shull 2 days ago
    There's a generic framework for attachment handling that will simplify your experience. Add the following import
    from com.ibm.tivoli.maximo.oslc.provider import AttachmentStorage
    And then after you call doclinksMbo = doclinksMboSet.add() do the following
    docStore=AttachmentStorage.getInstance()
    newFileName=docStore.getAttachmentQualifiedName(doclinksMbo,filename2)
    docStore.createAttachment(newFileName,outputReport,"application/pdf")
    Note: filename3 and filepath would go away as well as getDoclinksDir method. DOCTYPES are now metadata only meaning it doesn't change the folder structure for new attachments. On the NEWURLNAME and URLNAME you would set the value to newFileName
