  • 1.  Automation script to create TICKET
    Posted 11-27-2023 04:27
    Edited by Blaz Rakar 11-27-2023 04:28
    Hello all,
    I am trying to create automation script in Maximo 7.6.1.3 in custom application where main object is SR (app its created from original application VIEWSR) button when user click on it to create new SR so new TICKET and if is possible to even open this new ticket directly then in other application where main object is also SR. Maybe anybody know how to achieve that? I am trying for a start to create a TICKET from here and I get error "BMXAA4195E - A value is required for the Ticket field on the TICKET object." I tried something like that:
    from psdi.mbo import MboRemote
    # Create a new Ticket with a relationship to MXZTICKET
    ticketSet = mbo.getMboSet("MXZTICKET")
    newTicket = ticketSet.add()
    # Set mandatory fields for the Ticket object
    ##newTicket.setValue("TICKETID", str(ticketSet.getMbo(0).getUniqueIDValue()))
    newTicket.setValue("DESCRIPTION", "TEST dogodka")
    newTicket.setValue("CLASS", "SR")
    newTicket.setValue("STATUS", "NEW", MboConstants.NOACCESSCHECK)
    # Set other attributes as needed
    # Save the new Ticket
    ticketSet.save()
    # Get the ID of the newly created Ticket
    newTicketId = newTicket.getInt("TICKETUID")
    Best regards
    #ServiceProvider
    Blaz Rakar
    Slovenske Zeleznice d.o.o.
  • 2.  RE: Automation script to create TICKET
    Posted 11-27-2023 09:44
    Instead of an automation script to do this, you could add the createsr signature option to the application and to the select action menu.
    Out of the box, this creates a new SR and opens it in the application, if your application is a clone of the SR application, then this should work also.
    Stephen Hume
    Sheffield Scientific LLC
