Hello Experts,
We have a BIRT report requirement to calculate the Asset downtime between the status code ('INSTALL', 'REMOVE') from the asset status table. We have the below scenarios to check.
Scenario 1:
Asset: Install Date - Yes
Remove Date - Null [Then will calculate the downtime (Current date time - Change date(Install)]
Scenario 2:
Remove Date - Yes [ Then Change date(Remove)-Change date(Install)]
Scenario 3:
Remove Date - Yes
Install Date - Yes
Scenario 4:
Remove Date - Yes
Install Date - Yes
Remove Date - Yes
Install Date - Yes
Remove Date - Yes
I need help calculating Scenario 3 and Scenario 4. We are not sure how many entries for an asset with this combination.
Note: Out of box Asset time data will not be used for this calculation part.
Thanks for your help in advance.
Karthikeyan
#Reporting------------------------------
Karthikeyan K
IBM India Private Ltd
