Change default Status value on Select Assets form, Multiple Assets, Locations and CIs
  • 1.  Change default Status value on Select Assets form, Multiple Assets, Locations and CIs
    Posted 06-02-2023 05:04
    Edited by Dragos Chitu 06-02-2023 09:00
    I have the following request from business users.
    In WOTRACK app > Multiple Assets, Locations and CIs section > click "Select" button > Assets > Select Value > "Select Assets" form, Status field has default value of OPERATING (see print screen below).
    They asked to have by default multiple statuses, something like "=LIMITEDUSE,=OPERATING" (see print screen below).
    This is what I tried so far:
    • Export System XML > LIBRARY
    • Edit LIBRARY.xml adding the following line:
      <defaultvalue dataattribute="status" defaulttype="query" id="status_defaultvalue" value="=LIMITEDUSE,=OPERATING"/>
    • Import LIBRARY.xml
    • Restart Maximo servers
    No luck. The default Status value is still OPERATING.
    I've tried few variations of the procedure described above, same result: default Status is always OPERATING.
    However, I noticed that in Domain LOCASSETSTATUS, OPERATING is the default synonym value (of Internal Value OPERATING).
    If I change de default value to something else (e.g. LIMITEDUSE) then the default value which is appearing in the Status field on "Select Asset" form mentioned above is LIMITEDUSE.
    Any idea, how I can change the default value of Status field from OPERATING to multiple statuses (e.g. =LIMITEDUSE,=OPERATING)?
    Dragos
    Dragos Chitu
    EL
  • 2.  RE: Change default Status value on Select Assets form, Multiple Assets, Locations and CIs
    Posted 06-19-2023 15:57
    I looks like it's either a tough question or a complete uninteresting one. :)
    Nevertheless any suggestion on this would be appreciated.
    Dragos
    Dragos Chitu
    EL
