Hi Sammy-Joe,
I did a quick test with a Python script to build out a table of Actual Materials (you'll need to add more if you wanted to include Planned as well). Aside from the script, I created a Relationship on the COMMLOG object to WORKORDER and leveraging the existing Relationship to MATUSETRANS on the WORKORDER object. The read-only conditions may not be required in your case, if so, you can strip it out.
See below:
# Specify the TEMPLATEIDs for which this script should run
target_template_ids = ["ACT_MATERIAL"] # Replace with the specific TEMPLATEIDs you want
# Ensure mbo is not None and based on COMMLOG
if mbo is not None and mbo.isBasedOn("COMMLOG"):
commlog = mbo
# Always reset read-only status for MESSAGE and SUBJECT fields
commlog.setFieldFlag("MESSAGE", MboConstants.READONLY, False)
commlog.setFieldFlag("SUBJECT", MboConstants.READONLY, False)
# Check if the TEMPLATEID matches the specific ones we want to handle
if mbo.getString("TEMPLATEID") in target_template_ids:
# Get the related WORKORDER MboSet and move to the first record
workorder_set = commlog.getMboSet("WORKORDER")
workorder = workorder_set.moveFirst()
# Check if the workorder is not None before processing
if workorder is not None:
relationship_name = "SHOWACTUALMATERIAL" # Relationship name to the Materials from WORKORDER
# Fetch the related MBO set of Materials with ORDERBY clause if preferred
materials = workorder.getMboSet(relationship_name)
materials.setOrderBy("LINETYPE ASC")
# Initialize the table structure with headers
materials_table = (
'<table border="1" style="width:600px; table-layout:auto; border-collapse:collapse; margin:0;">'
'<tbody>'
'<tr>'
'<td style="white-space:nowrap; padding: 5px; border: 1px solid #ccc;"><strong>Line Type</strong></td>'
'<td style="white-space:nowrap; padding: 5px; border: 1px solid #ccc;"><strong>Description</strong></td>'
'<td style="white-space:nowrap; padding: 5px; border: 1px solid #ccc;"><strong>Quantity</strong></td>'
'<td style="white-space:nowrap; padding: 5px; border: 1px solid #ccc;"><strong>Line Cost</strong></td>'
'<td style="white-space:nowrap; padding: 5px; border: 1px solid #ccc;"><strong>Unit Cost</strong></td>'
'<td style="white-space:nowrap; padding: 5px; border: 1px solid #ccc;"><strong>Issue Type</strong></td>'
'</tr>'
# Loop through each Material and add rows to the table
if not materials.isEmpty():
for i in range(materials.count()):
material = materials.getMbo(i)
# Extract necessary fields from the Material Mbo
line_type = material.getString("LINETYPE")
description = material.getString("DESCRIPTION")
positive_quantity = material.getString("POSITIVEQUANTITY")
line_cost = material.getString("LINECOST")
unit_cost = material.getString("UNITCOST")
issue_type = material.getString("ISSUETYPE")
# Add a row to the table with the material details
materials_table += (
'<tr>'
'<td style="white-space:nowrap; border: 1px solid #ccc;">' + line_type + '</td>'
'<td style="white-space:nowrap; border: 1px solid #ccc;">' + description + '</td>'
'<td style="white-space:nowrap; border: 1px solid #ccc;">' + positive_quantity + '</td>'
'<td style="white-space:nowrap; border: 1px solid #ccc;">' + line_cost + '</td>'
'<td style="white-space:nowrap; border: 1px solid #ccc;">' + unit_cost + '</td>'
'<td style="white-space:nowrap; border: 1px solid #ccc;">' + issue_type + '</td>'
'</tr>'
# Close the table
'</tbody>'
'</table>'
# Cleanup and close the MboSet
materials.close()
# Inject the generated table into the MESSAGE field of the Communication Template
if materials_table:
# Replace the placeholder in the communication template, e.g., `#MATUSETRANS#`
message = commlog.getString("MESSAGE")
updated_message = message.replace("#MATUSETRANS#", materials_table)
commlog.setValue("MESSAGE", updated_message, MboConstants.NOACCESSCHECK)
# Set the MESSAGE/SUBJECT field to read-only for the specific templates
commlog.setFieldFlag("MESSAGE", MboConstants.READONLY, True)
commlog.setFieldFlag("SUBJECT", MboConstants.READONLY, True)
Hope this helps. Let us know how you make out.
Cheers,
Matt F
Sent: 12-10-2024 02:52
Subject: Communication template adding all worklogs
Hello Jade,
I'm having the same problem as the original poster and I'm eager to try out your method. I just have a few extra questions.
In what script language is your script written? Python?
And if I wanted to create the same effect for let's say all the materials that were used, could I simply make a new placeholder (#MATUSE#) and then update all relevant lines in your script?
Thank you for you time,
Sammy-Joe
Sammy-Joe Goossens
DHL Aviation
Sent: 10-24-2023 08:46
As far as I am aware, out-of-the-box Maximo doesn't allow for enumeration of child records w/in communication templates (i.e. there's not a way provided to list all work log entries, for example).
We have worked around this using the following approach:
1) make up some short of placeholder like #WORKLOG# and add that to the message of your communication template.
2) add an automation script that runs whenever the message body is updated--this script should look for #WORKLOG#.
3) if that placeholder is found, the script opens the appropriate MBO set and either builds a list or a table of work log entries and then replaces the placeholder #WORKLOG# with the HTML (list, table, etc).
I've attached our script--I am definitely on the amateur side of scripting, and so I'm sure others could provide insights about how to do this better...but this approach has worked for us!
Jade Warren
Great River Energy
