  • 1.  Complete Work Order
    Posted 07-18-2025 09:46
    Hi all, new here!
    My users are unable to complete work orders without getting errors, one is "Status cannot be changed" or they simply don't have the option to complete it as I do (Administrator). I have added every application and application options, in their security groups that make sense. All that have to do with work orders. Any ideas what I am missing? This seems so simple.
    In my system we do not do actual work like PM's or anything. The work order is simply created after a service request is approved. It closes and the wo is automatically created. Full disclosure, I did not create this workflow.
    Thank you
    Sam
    Samantha JM
  • 2.  RE: Complete Work Order
    Posted 07-21-2025 08:35
    Security permissions for complete require the user to have the ability to change status, the ability to complete work, and the ability to initiate the work order (if it is not already in an INPRG status). A lot of people forget to grant the initiate permission so I would make sure that it's granted.
    Beyond that, it could be configuration in your environment such as conditions on the domain values. Some customers like to hide COMP unless some criteria is met (such as a labor transaction is entered). I hate using conditions on domains because it's not clear to the user what they need to do to fix the issue which is a frustrating user experience. You can check if you have conditions on the domain values by going to the Domains application, opening the WOSTATUS domain, and then for the COMP value(s) using the View/Modify Conditions to see conditions that have been tied to the domain value.
    You mentioned workflow and there is a process in workflow to prevent status changes outside of the workflow. However, you should receive a different error message in that scenario which is why I didn't go down that path.
